> Another Throttle Body Question, Adjustment screw
914Rookie
post May 19 2005, 10:32 AM
What is a rough baseline adjustment for the screw in the throttle body? how far should it be backed off from fully closed ?. (IMG:http://www.914world.com/bbs2/html/emoticons/huh.gif) I think mine is so far off it's causing other problems. Also, how many "clicks" from stopped should the box be. Thanks. (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif)
Greg
914Rookie
post May 19 2005, 10:59 AM
Thanks redshift,
symptoms are idle way too high, and when trying to lower via the adjustment screw it seems to go right past 950 rpm to too low then stalls. This was not a problem before I started screwing around with the adjustment screw. I changed a couple vacuum hoses so that these are now leak free. But none of this was done with the car at proper temps. I'll check the AAR but it has run fine 'til I turned the screw. (IMG:http://www.914world.com/bbs2/html/emoticons/blink.gif)
914Rookie   Another Throttle Body Question   May 19 2005, 10:32 AM
914Rookie   Forget to give some important info. Car is '7...   May 19 2005, 10:36 AM
redshift   The brain isn't something you can just say ...   May 19 2005, 10:39 AM
914Rookie   Thanks redshift, symptoms are idle way too high,...   May 19 2005, 10:59 AM
mattillac   i think there should be a mark on the ECU box corr...   May 19 2005, 11:35 AM
redshift   Yes, Matt is right.. There is a point on the coll...   May 19 2005, 05:37 PM
914Rookie   Now the car won't idle at all
- Lo-Fi Version Time is now: 13th March 2026 - 08:44 PM
