Intake length vs torque, Just anthoer carb question No boobs |
Joe Ricard |
May 18 2005, 02:03 PM
So I have short intakes and 44IDF's with 38mm vents
How long of an intake should I go to with these carbs or should I go to 40 IDF's with 32 vents or 28 vents. I have some longer runner intakes and the other carbs so it's just a matter of experimenting I guess. 2.0L Bus piston Web 86B portmatch intake and exhaust ports. 13lb flywheel Bursch SSI Car weighs 1965 lbs 205/50-15 Kumho V700 R tires. Thought of playing with spacers under the carbs to get more length and maybe spacer under the common length velocity stack. Looking for more torque down lower to pull harder exiting the apex of tight AX turns. Whose got the experience of really been there done that? great gains or don't bother. |
Joe Ricard |
May 19 2005, 02:13 PM
OK Well I'm going to do it and then write down the recipe including results.
So base line has already been described. Above 4000 RPM it rocks Short intakes 50mm opening, 44IDF, Velocity stacks short air filter. SSI Bursch, 86B cam 2.0L heads port matched. Bus pistons all the compression I can get. Hauls ass to 120 MPH |
Lo-Fi Version | Time is now: 2nd June 2024 - 11:35 AM |
