Tony's Subaru Conversion Thread |
TonyAKAVW |
May 19 2005, 11:10 AM
That's my ride. Group: Members Posts: 2,151 Joined: 17-January 03 From: Redondo Beach, CA Member No.: 166 Region Association: None |
Well, I figured since there has been some pickup in momentum on this project that I would start a thread on my progress. Not to mention its a good way to share whatever ideas I pick up along the way.
The project started in January 2003 when I picked up the silver roller pictured below. Its a '74 and was pretty much stripped. It had a suspension and a few other parts but was missing a lot of major things like and engine, transmission, glass, hoods, gas tank, interior, wheels, etc. etc. The story of my acquisition of this roller is in this thread: http://www.914world.com/bbs2/index.php?act=...&f=2&t=7991&hl= After arriving at home: http://www.914world.com/bbs2/index.php?act=...&f=2&t=8963&hl= This project got a bit of a slow start. I had to first part and chop up my first 914 and dispose of it. It was badly rusted and where itwasn't rusted it was bondo'd. This was going to be a replacement body for that car. Then last summer I picked up the yellow '70 roller that is now my daily driver. Since then I've spent most of my 914 time fixing it up and getting it ready for WCC. Now that its in a pretty much stable state and WCC is over I can concentrate on this car. The current plan is that it will get a Subaru 2.5L naturally aspirated engine in a conversion very similar to Scott Thacher's. The basic timeline is like this: 1. Fix up the body enough to make it roadworthy. 2. Put together the drivetrain (engine, adapter, transmission) 3. Install drivetrain and remaining parts 4. Install an exhaust system and wire up the engine, make it ready to drive 5. Install enough interior to drive it. 6. Drive it around a bit, fix whatever things don't work right 7. Flare the fenders (GT flares) 8. body and paint 9. Finish the interior 10.Performance mods - cams, etc. I'm hoping that I get it at least roadworthy within a year, and the rest of the stuff within a year after that. Its possible I could get it done faster but we'll see. This is a big project. Here's the car as it was when I brought it home: Attached image(s) |
Hydra |
May 20 2005, 03:56 AM
Quia nominor LEO Group: Members Posts: 162 Joined: 11-December 04 Member No.: 3,261 |
Hey tony,
good to see you started working on your conversion. As for the tranny setup, why don't you use a subaru 5 sp. manual tranny? pros: -it's a lot cheaper than a 901 (around 150$ for one in good condition -it will allow you to have the engine placed about 5 inches more to the back, giving you more space for your radiator setup. -and most importantly, you won't need the kennedy adapter kit (much less $$$) cons: -you will need to fabricate your own mounts for it. -adapt a cable gear shift linkage -adapt axles (but that is easy if you consider doing frankenaxle out of the subaru axles on the tranny end, and the 914 axles on the wheel hub end) (IMG:http://www.914world.com/bbs2/html/emoticons/welder.gif) my 0.02$ Best of luck btw: i'm working on my eg33 conversion right now, and trying to figure out a way to mount the radiator in the optimal position for cooling, and it is such a major PITA. oh and scott, i could really need those scoop pics... (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif) |
