> Intake length vs torque, Just anthoer carb question No boobs
Joe Ricard
post May 18 2005, 02:03 PM
CUMONIWANNARACEU
So I have short intakes and 44IDF's with 38mm vents
How long of an intake should I go to with these carbs or should I go to 40 IDF's with 32 vents or 28 vents.
I have some longer runner intakes and the other carbs so it's just a matter of experimenting I guess.
2.0L Bus piston Web 86B portmatch intake and exhaust ports. 13lb flywheel Bursch SSI Car weighs 1965 lbs 205/50-15 Kumho V700 R tires.
Thought of playing with spacers under the carbs to get more length and maybe spacer under the common length velocity stack. Looking for more torque down lower to pull harder exiting the apex of tight AX turns.
Whose got the experience of really been there done that? great gains or don't bother.
Jake Raby
post May 20 2005, 07:50 PM
Engine Surgeon
Due to the intake and exhaust port designs the TIV is a different puppy than any other engine I have ever read about or worked with. (IMG:http://www.914world.com/bbs2/html/emoticons/pissoff.gif)
My data has been specifically done with the TIV so I really don't give a damn about theory with other engines because it just doesn't impact the TIV! (IMG:http://www.914world.com/bbs2/html/emoticons/monkeydance.gif)
Now with that out of the way I can tell you that runner length, especially with carbs is a huge thing to the engine's combination and is even impacted by something so far from the combo as the exhaust system.
Generally long runners and tall stacks boost down low power but they kill top end- I have seen this SO MANY TIMES when the opposite is conventional wisdom. Read those posts and what I wrote on them, its a repeatable thing that my dyno shows me over and over again.... (IMG:http://www.914world.com/bbs2/html/emoticons/aktion035.gif)
Now with that being said the 3 liter uses my Billet heads with a TI style exhaust port and one healthy D shaped intake port - It does NOT follow this trait! This absolutely indicates that the difference is the standard TIV heads. I plan on testing this on the 3 liter when I test my Billet heads Vs the super worked 2 liter 914 heads to show the power differences... That will tell the tale on the same engine with the same CR and etc, just different heads.
Comparing the TIV with another engine is the first and biggest mistake made by newbies or even TI tuners.
BTW- I have played with variable length stacks and found some small benefits on high speed engines, according to the exhaust design but generally its too small to matter.. My belief is that the can am guys did it to keep the stacks from robbing air from each other which can be a big issue with a healthy engine at that RPM.
Direct back to back dyno testing of the stacks ad intakes is easy and fun and its always part of designing a new combo- to find out what it really wants for later...
FYI_ as stacks and runner lengths change so does the jetting in the carbs... Air speed greatly effects the atomization of the fuel and the runner length effects the mixture motion of the charge so don't be suprised if a jet change and timing change makes more power or less power for you as you experiment. In some tests the engine wanted as much as 4 degrees less ignition timing, indicative of efficiency changes and in this case it was a positive change!
To date the best stack I have found with engines built my way with our heads and camshafts is the 1-7/8 stack (stock on 44 webers) and the CB style manifolds shortened 1 full inch.... On our FP engines we run the manifold length as short as the rules allow with short stacks with one hell of a tulip on them but very litttle height to them, basically they are flared all the way down to the carb entrance- Thats just one key to digging up 186 HP from an 1832cc engine (IMG:http://www.914world.com/bbs2/html/emoticons/boldblue.gif)
Its ALL in the combo fellas- forget that Chevy, 911 and TI knoowledge and start letting this engine teach you how to manipulate it- don't question it just listen, try and try again and learn!
Joe Ricard   Intake length vs torque   May 18 2005, 02:03 PM
Dr. Roger   Please correct me if i'm wrong anyone..... Ge...   May 18 2005, 03:25 PM
SirAndy   <...   May 18 2005, 04:18 PM
Aaron Cox   pull a move like mazda racing did- varying intake...   May 18 2005, 04:20 PM
SirAndy     May 18 2005, 04:26 PM
lapuwali   Andy's right. Long = low-end weighted power c...   May 18 2005, 04:40 PM
Dr. Roger   Well actually it's got way more than just inta...   May 18 2005, 05:00 PM
lapuwali   Nice theory. Wrong, but nice-sounding. You can t...   May 18 2005, 05:46 PM
jwalters   Yea, Andy is correct-- A good view of this in wor...   May 18 2005, 05:47 PM
Tom73   So why to make HP on a V8 do you use a "high rise"...   May 18 2005, 07:26 PM
Dr. Roger   That's right... http://www.91...   May 18 2005, 07:36 PM
Dr. Roger   OHHH CRAP! Why-oh-why will my hood not fit rig...   May 18 2005, 07:40 PM
Joe Ricard   Well I knew all that. But what I want is the recip...   May 18 2005, 07:43 PM
Joe Ricard     May 18 2005, 07:46 PM
SGB   Personal experience: really really short intake =...   May 18 2005, 07:49 PM
bondo   What I don't understand is why runner length w...   May 18 2005, 07:52 PM
scott thacher   i did get a ride in joe's car, with the except...   May 18 2005, 08:09 PM
Joe Ricard   Yea Scott, Your motor in my car and it would be pr...   May 18 2005, 08:15 PM
scott thacher   nope i have done almost nothing... got a new batte...   May 18 2005, 08:21 PM
messix   quick and dirty big and short= high rpm power ...   May 18 2005, 09:37 PM
Joe Ricard   OK Well I'm going to do it and then write down...   May 19 2005, 02:13 PM
JmuRiz   What was the thinking behind this type of setup......   May 20 2005, 08:32 AM
URY914     May 20 2005, 09:18 AM
kwales   Looks like organ pipes- each one tuned to a differ...   May 20 2005, 09:24 AM
don9146   Didn't Jake do a test of different length Webb...   May 20 2005, 09:30 AM
Dr. Roger   Excellent info. Quote: But there's also a per...   May 20 2005, 10:12 AM
Dr. Roger   Oh, on the Can Am thing... Those stacks were anot...   May 20 2005, 10:21 AM
bondo   So how DO you measure throttle response? That...   May 20 2005, 11:33 AM
JmuRiz   Great info on the ducati airbox design! The b...   May 20 2005, 11:44 AM
Dr. Roger   Hmmm, in my limited experiences with a few small b...   May 20 2005, 07:17 PM
Jake Raby   Due to the intake and exhaust port designs the TIV...   May 20 2005, 07:50 PM
lapuwali   Jake, I don't know where this "conventional w...   May 20 2005, 08:38 PM
J P Stein   From what I have read on the long stacks/short sta...   May 20 2005, 08:59 PM
Joe Ricard   Well the butt dyno tells me I have more torque low...   May 30 2005, 02:33 PM
Air_Cooled_Nut   ...   May 30 2005, 04:44 PM
messix   the stacks jake is using are doing nothing but smo...   May 30 2005, 10:18 PM
- Lo-Fi Version Time is now: 12th July 2025 - 04:10 PM
