Intake length vs torque, Just anthoer carb question No boobs |
Joe Ricard |
May 18 2005, 02:03 PM
So I have short intakes and 44IDF's with 38mm vents
How long of an intake should I go to with these carbs or should I go to 40 IDF's with 32 vents or 28 vents. I have some longer runner intakes and the other carbs so it's just a matter of experimenting I guess. 2.0L Bus piston Web 86B portmatch intake and exhaust ports. 13lb flywheel Bursch SSI Car weighs 1965 lbs 205/50-15 Kumho V700 R tires. Thought of playing with spacers under the carbs to get more length and maybe spacer under the common length velocity stack. Looking for more torque down lower to pull harder exiting the apex of tight AX turns. Whose got the experience of really been there done that? great gains or don't bother. |
J P Stein |
May 20 2005, 08:59 PM
From what I have read on the long stacks/short stacks Can Am deal, it was to tune out a two peak torque curve with a mid range dip....basicly treating the engine like 2 seperate 4 cylinder engines to smooth things out.
Note the short stacks are pretty tall.....that is probably a fuel reversion issue...my best guess. |
Lo-Fi Version | Time is now: 2nd June 2024 - 10:38 AM |
