| gregrobbins |
May 21 2005, 01:29 AM
Member: Team NARP ![]() ![]() ![]() Group: Members Posts: 1,515 Joined: 23-March 04 From: Arizona Member No.: 1,844 Region Association: Southwest Region |
This crank is being offered by a shop that builds off road air cooled race motors. Would this work on a 2270? Or are you better off with a crank that has 55 mm rod journals and uses type I rods? This crank is priced at $300 which seem reasonable. |
| Verruckt |
May 21 2005, 10:45 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 716 Joined: 14-July 04 From: Midwest Member No.: 2,348 |
Jake
What about the SB Chebby rods? Do they not give as good of rod ratio as the type 1 rods? Just wondering becuase I know there is an abundance of sb chebby rods available, with different lengths too, and they are fairly inexspensive. |
gregrobbins Stroker Crank May 21 2005, 01:29 AM
skline I am not sure about the 55mm but I know you can ge... May 21 2005, 01:41 AM
SLITS Greg...in order to get to the 78 mm stroke, they h... May 21 2005, 01:42 AM
Bleyseng 50mm is the 2.0L rod size so hmm, what is availabl... May 21 2005, 07:27 AM
jasons I think Demello stroked my crank(insert Beavis and... May 21 2005, 08:34 AM
LouisCypher You can have the stock rods lightened by 200 grams... May 21 2005, 08:35 AM
jasons May 21 2005, 08:36 AM
Jake Raby It has stock 2 liter rod journals..
Like mentione... May 21 2005, 09:59 AM
Type 4 2.0 Rod Modded for 78mm Stroke.
Cunningham makes ... May 21 2005, 10:02 AM
LouisCypher Stock rod weight = approx. 800 gr.
Lightening = ap... May 21 2005, 10:35 AM
! Been over 10 years....but I remember doing a strok... May 21 2005, 10:43 AM
Jake Raby Chevy rods are generally too wide on the big end a... May 21 2005, 05:29 PM
V6914 ![]() ![]() |
Lo-Fi Version | Time is now: 12th September 2026 - 04:50 AM |
