McMark |
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 20,180 Joined: 13-March 03 From: Grand Rapids, MI Member No.: 419 Region Association: None ![]() |
I'm still struggling to get my KitCarlson EMS running smoothly. It's a challenge when you're tuning FI and Ignition.
I read some threads on ShopTalk Forums where Jake recommends 12 degrees initial advance and 28 degrees full advance, all in at 3000 rpms. So I dialed the ignition controls in to these figures. Checked the setting with a timing light and what's showing on the EMS monitor seems to match what's showing with the adjustable timing light. This is a wasted spark system and I've been ambiguously warned that a standard timing light "won't work" with a wasted spark system. This doesn't make sense to me though. The first issue I need to deal with is that the car won't rev above 4000 rpms. When I first started setting this up I had the same issue and adding in advance cured the issue. I trust Jakes recommendation and so I'm looking for other sources of this issue. Currently my logic tells me that if the system is too rich above 4000 rpms it would respond to more advance. Spark earlier gives the rich mixture more time to burn. I'll be playing around with this idea tomorrow, but I'd like to hear what'cha got to say. |
Mark Henry |
that's what I do! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,065 Joined: 27-December 02 From: Port Hope, Ontario Member No.: 26 Region Association: Canada ![]() |
Dave remember that wasted spark systems have a coil for every 2 cylinders, The wasted spark is of no issue. Many of todays cars use a wasted spark system....just like batch fired injectors. My SDS uses both with no problems. |
Lo-Fi Version | Time is now: 4th July 2025 - 08:53 PM |
