| gregrobbins |
May 21 2005, 01:29 AM
Member: Team NARP ![]() ![]() ![]() Group: Members Posts: 1,515 Joined: 23-March 04 From: Arizona Member No.: 1,844 Region Association: Southwest Region |
This crank is being offered by a shop that builds off road air cooled race motors. Would this work on a 2270? Or are you better off with a crank that has 55 mm rod journals and uses type I rods? This crank is priced at $300 which seem reasonable. |
| Type 4 Unleashed |
May 22 2005, 12:53 AM
CREATIVE TYPE lV ENGINEERING ![]() ![]() ![]() Group: Retired Members Posts: 787 Joined: 20-June 04 From: Aliso Viejo, ca Member No.: 2,231 Region Association: None |
Here, is a pic of a rabbit rod, bushed for a chevy .927 pin, the bolts have been turned around, and the bolts are 3/8 big block chevy ARP Wave loc Bolts, in it's present form, the rod weights 662 grams, it can be lightened at least 100g, the length is 5.355. These are going in my motor next week. The other rod, is out of a Jetta or Gulf, it is 5.670" long, and the piston pin, is oiled from the rod bearing through the beam of the rod. My current engine is 105.7 x 75, I was going to have my 75mm stroke crank, offset ground from 2.0 ltr journal size of 1.967 to rabbit journal size of 1.805, taking my 75mm stroke to 78.4mm, but I just got a line on a 80mm crank with rabbit journals, I may go that route instead. Stroke and rod combinations are limited, only by the imagination Attached image(s)
gregrobbins Stroker Crank May 21 2005, 01:29 AM
skline I am not sure about the 55mm but I know you can ge... May 21 2005, 01:41 AM
SLITS Greg...in order to get to the 78 mm stroke, they h... May 21 2005, 01:42 AM
Bleyseng 50mm is the 2.0L rod size so hmm, what is availabl... May 21 2005, 07:27 AM
jasons I think Demello stroked my crank(insert Beavis and... May 21 2005, 08:34 AM
LouisCypher You can have the stock rods lightened by 200 grams... May 21 2005, 08:35 AM
jasons May 21 2005, 08:36 AM
Jake Raby It has stock 2 liter rod journals..
Like mentione... May 21 2005, 09:59 AM
Type 4 2.0 Rod Modded for 78mm Stroke.
Cunningham makes ... May 21 2005, 10:02 AM
LouisCypher Stock rod weight = approx. 800 gr.
Lightening = ap... May 21 2005, 10:35 AM
! Been over 10 years....but I remember doing a strok... May 21 2005, 10:43 AM
Verruckt Jake
What about the SB Chebby rods? Do they not g... May 21 2005, 10:45 AM
Jake Raby Chevy rods are generally too wide on the big end a... May 21 2005, 05:29 PM
V6914 ![]() ![]() |
Lo-Fi Version | Time is now: 12th September 2026 - 04:49 AM |
