> Games with Stub Axles, (insert grumbling here)
Rusty
post May 22 2005, 12:17 PM
I charged into the garage... determined to R&R my CV joint boots on the drivers side.
I unbolted the CV from the gearbox, and wiped down the grease that had been slung around. Started to unbolt the CV from the outer side, and realized that I'll never be able to get it apart. It's all snuggly in the trailing arm. So... the only thing to do is pull the stub axle. Never done it before, but what the heck.
Jack the car up, pull the wheel, pull the retaining pin... a little leg muscle, and the nut spins free! (IMG:http://www.914world.com/bbs2/html/emoticons/smilie_pokal.gif)
Then, things get difficult:
- rap on the stub with a mallet - no luck
- spray with PB Blaster and wait
- get a 2x4 up against the stub and start wailing. 2x4 disintegrates and I'm left with a dumb look on my face. (IMG:http://www.914world.com/bbs2/html/emoticons/blink.gif)
- start wailing on the stub itself with a hammer. Discover the joy of maybe having screwed up the threads. (IMG:http://www.914world.com/bbs2/html/emoticons/mad.gif)
So... what now? I think I need a new stub axle & castellated nut. Maybe I can chase the threads, but I kind of doubt it.
How the heck do I remove this thing without screwing anything else up? (IMG:http://www.914world.com/bbs2/html/emoticons/unsure.gif)
-Rusty (IMG:http://www.914world.com/bbs2/html/emoticons/smoke.gif)
skline
post May 22 2005, 12:25 PM
Born to Drive
I used a puller on mine and it came right out, getting it back in is the hard part. You may wind up replacing your bearings while you are in there. I would if I went that far. But that is just me.
Lawrence   Games with Stub Axles   May 22 2005, 12:17 PM
SLITS   BFH (as in 2 - 5 lb sledge)............It should c...   May 22 2005, 12:20 PM
Lawrence   I should have mentioned... these are /4 stub axles...   May 22 2005, 12:23 PM
Lawrence     May 22 2005, 12:24 PM
skline   I used a puller on mine and it came right out, get...   May 22 2005, 12:25 PM
RustyWa   Just did mine. One side of the car came right out...   May 22 2005, 12:27 PM
Lawrence     May 22 2005, 12:27 PM
skline   They have to be pulled in very consistent or the b...   May 22 2005, 12:32 PM
Aaron Cox   rusty.. this is why you leave the nut on the threa...   May 22 2005, 12:35 PM
SLITS   Mine were never that hard, but rust of the bearing...   May 22 2005, 12:35 PM
Verruckt   Get some BRASS!!! I used to work in a...   May 22 2005, 01:03 PM
Lawrence   So why is it that I could mess up my bearings? I...   May 22 2005, 01:36 PM
brp914     May 22 2005, 01:50 PM
Bleyseng   BFH made of Brass works fine...... hit it, more PB...   May 22 2005, 02:18 PM
Eric_Shea   Your going to ruin the bearing taking the stub axl...   May 22 2005, 02:24 PM
hmeeder   Rusty; Just went through this a couple of months ...   May 22 2005, 05:07 PM
Eric_Shea
  May 22 2005, 05:28 PM
skline   Rusty, if I were there, I could have them out in l...   May 22 2005, 05:35 PM
Eric_Shea
  May 22 2005, 05:38 PM
Lawrence   Anyone from the Club is welcome in my home... to v...   May 22 2005, 05:41 PM
Verruckt     May 22 2005, 05:45 PM
SLITS     May 22 2005, 05:45 PM
skline   Well, I would love to come back and see my old Alm...   May 22 2005, 05:46 PM
Eric_Shea   Let me know of you need a new stub axle. I can ha...   May 22 2005, 05:46 PM
Eric_Shea
  May 22 2005, 05:49 PM
hmeeder   Stubs, hubs, schlubs. I meant to say hubs, but on...   May 22 2005, 06:06 PM
black73   I took the easy way out when replacing my rear bea...   May 22 2005, 07:05 PM
ClayPerrine   http:...   May 28 2005, 04:26 PM
Verruckt
- Lo-Fi Version Time is now: 17th September 2026 - 06:08 PM
