> I jinxed myself, if it's not one thing...
Jenny
post May 24 2005, 09:56 PM
it's another. Finally got the car in a very decent shape, and all stoked about the upcoming breakfast. Driving it today on the freeway, and I hear a screech. then nothing. I thought maybe it was the radio. But on my way home on surface streets, the screeching is back, louder and much more frequent. I'd describe it like brakes that screech, but instead of it happening when I'm braking, it's when the car's going. I hear it in the lower 3 gears. But that may just be because the engine noise is too loud in 4 & 5 for me to hear. The screeching is repetitive, slowly at first, then more frequent the faster I go. Which makes me think it's something to do with the wheels. I've had bad bearings clunking before. This doesn't sound like it. This is like screech..... screech...... screech.....screech..screech.. screech. schreeeeeeeeech the faster I go. But it happens when I'm cruising up to a red light as well. I haven't been able to figure out if it's doing it during acceleration or braking. It's not favoring either.
Any ideas on where to start? I've checked the bolts to make sure they're on tight. Right when i got home, I checked each wheel for smoke or burning smells, etc.. Nada. Front wheels are hot, but that's the brakes, right?
(IMG:http://www.914world.com/bbs2/html/emoticons/headbang.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/headbang.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/headbang.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/headbang.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/headbang.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/headbang.gif)
Jen
redshift
post May 24 2005, 10:32 PM
Bless the Hell out of you!
My gut tells me it's in my rear passenger brake thingy area...
Jen, get it making noise, and drive by a wall, or have someone listen for the noise... my friend told me it's from the rear end, he couldn't tell which side.
Excellent advice Eric! That could explain why mine seems to only do it after a couple rainy days.. my drive is covered with crushed stone about the right size to do that exact thing. I'll look.
M
Jenny   I jinxed myself   May 24 2005, 09:56 PM
redshift   It stays about the same pitch, but it just happens...   May 24 2005, 10:00 PM
Jenny   Yeah, same pitch. Think squeaky brake pads. But ti...   May 24 2005, 10:04 PM
skline   If it is not when braking but accelerating, My fir...   May 24 2005, 10:07 PM
redshift   After a couple rainy days, my car does something s...   May 24 2005, 10:10 PM
drew365   How about a loose alternator belt? I always forget...   May 24 2005, 10:10 PM
redshift   Mine sounds like a rear wheel bearing. Saved by t...   May 24 2005, 10:18 PM
McMark   "Saved By The Bell" http://www.914w...   May 24 2005, 10:20 PM
Jenny   I want to say acceleration, but I also heard it wh...   May 24 2005, 10:22 PM
redshift   If it's like mine, it happens even when the cl...   May 24 2005, 10:22 PM
drew365     May 24 2005, 10:22 PM
Jenny   ...   May 24 2005, 10:24 PM
ThinAir914   If it's the alternator belt then the noise wil...   May 24 2005, 10:25 PM
redshift   Well, then I guess it can't be the other thing...   May 24 2005, 10:29 PM
Eric Taylor   I know this sounds stupid but it happened to me   May 24 2005, 10:30 PM
redshift   My gut tells me it's in my rear passenger brak...   May 24 2005, 10:32 PM
Jenny   It only happens when the car's in motion. So p...   May 24 2005, 10:33 PM
Jenny   sounds like the rear pass side to me, but I had th...   May 24 2005, 10:34 PM
redshift   Or, it could be a rock, or some other debris, as E...   May 24 2005, 10:36 PM
Eric Taylor     May 24 2005, 10:38 PM
ThinAir914   I've had Eric's experience with several di...   May 24 2005, 10:38 PM
Jenny   A-ha! Then it may be the throwout bearing. I...   May 24 2005, 10:41 PM
Eric Taylor   It could just be when certain area's of the in...   May 24 2005, 10:48 PM
skline   Well, I hope you post what it is when you find out...   May 24 2005, 10:50 PM
Dr. Roger   that high pitched thing is usually bearings or bra...   May 24 2005, 11:09 PM
swood   ...   May 24 2005, 11:12 PM
Jenny   Thanks for all the input, guys. As I'm not mec...   May 24 2005, 11:14 PM
SirAndy     May 24 2005, 11:28 PM
redshift     May 24 2005, 11:42 PM
Carl   Make sure the e-brake is fully released. Try appl...   May 24 2005, 11:42 PM
john rogers   Does your car still have the dust shields on the i...   May 24 2005, 11:59 PM
Elliot Cannon   Is the noise louder when turning one way or anothe...   May 25 2005, 12:26 AM
Britain Smith   Mine had the same issues when the alternator beari...   May 25 2005, 12:26 AM
jkeyzer   The day before the last lunch at Tied House, one t...   May 25 2005, 12:33 AM
Jenny   Thanks britain & Jeff. It's really generous of...   May 25 2005, 12:43 AM
Aaron Cox   i had a squeely rear wheel bearing... at a certai...   May 25 2005, 01:01 AM
Paul Illick   Don't pull the transaxle if you don't have...   May 25 2005, 05:47 AM
Gint   Best advice I can give you Jen is to take it to th...   May 25 2005, 06:59 AM
Jeroen   try driving it till you hear the sound then (gentl...   May 25 2005, 07:01 AM
ArtechnikA   do you still have the brake "dust shields" ? if o...   May 25 2005, 07:17 AM
914 novice   Jen, I live off santa teresa and lean.If you like ...   May 25 2005, 08:18 AM
Jenny   Thanks guys. Brad PM'd me and he thinks it may...   May 25 2005, 10:02 AM
john rogers   If the throwout bearing is failing it will become ...   May 25 2005, 10:20 AM
Lyressa Roberts   ...   May 25 2005, 10:22 AM
tnorthern   Well, I haven't seen anyone else post this so ...   May 25 2005, 10:41 AM
Toast   ...   May 25 2005, 11:49 AM
Jenny   Front passenger wheel bearing. I'm almost posi...   May 25 2005, 11:43 PM
nebreitling   lmao jenny.... bring it over here -- fuck 'em...   May 25 2005, 11:48 PM
Jenny   Wow...   May 27 2005, 02:03 AM
Jenny   more   May 27 2005, 02:04 AM
Jenny   Nice, huh? Jeff Keyzer was nice enough to teach me...   May 27 2005, 02:08 AM
skline   Well, I have been wrong before, I am sure I will b...   May 27 2005, 02:09 AM
jkeyzer   The inner race of the outside bearing froze to the...   May 27 2005, 02:33 AM
Lyressa Roberts   I became an expert at changing those out on my 69 ...   May 27 2005, 08:54 AM
- Lo-Fi Version Time is now: 6th July 2025 - 09:17 PM
