I jinxed myself, if it's not one thing... |
Jenny |
May 24 2005, 09:56 PM
Advanced Member Group: Members Posts: 4,060 Joined: 6-January 03 Member No.: 96 Region Association: None |
it's another. Finally got the car in a very decent shape, and all stoked about the upcoming breakfast. Driving it today on the freeway, and I hear a screech. then nothing. I thought maybe it was the radio. But on my way home on surface streets, the screeching is back, louder and much more frequent. I'd describe it like brakes that screech, but instead of it happening when I'm braking, it's when the car's going. I hear it in the lower 3 gears. But that may just be because the engine noise is too loud in 4 & 5 for me to hear. The screeching is repetitive, slowly at first, then more frequent the faster I go. Which makes me think it's something to do with the wheels. I've had bad bearings clunking before. This doesn't sound like it. This is like screech..... screech...... screech.....screech..screech.. screech. schreeeeeeeeech the faster I go. But it happens when I'm cruising up to a red light as well. I haven't been able to figure out if it's doing it during acceleration or braking. It's not favoring either.
Any ideas on where to start? I've checked the bolts to make sure they're on tight. Right when i got home, I checked each wheel for smoke or burning smells, etc.. Nada. Front wheels are hot, but that's the brakes, right? (IMG:http://www.914world.com/bbs2/html/emoticons/headbang.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/headbang.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/headbang.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/headbang.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/headbang.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/headbang.gif) Jen |
Eric Taylor |
May 24 2005, 10:38 PM
Senior Member Group: Members Posts: 909 Joined: 1-June 03 From: Newport, OR/Eugene Oregon- UO Member No.: 770 |
Applys and removes the pressure from the clutch via the presure plate. It's the thing attached to the other end of clutch cable basically. It's on the input shaft and the shaft spins around inside it. Could make a nice high pitched whine if it's wearing out or not properly lubed. I always thought that you knew when one was going if it whined when you engaged and disengaged the clutch. Is this true? Eric |
Lo-Fi Version | Time is now: 10th June 2024 - 07:44 PM |
