Joe Ricard |
CUMONIWANNARACEU ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,811 Joined: 5-January 03 From: Gautier, MS Member No.: 92 ![]() |
So I have short intakes and 44IDF's with 38mm vents
How long of an intake should I go to with these carbs or should I go to 40 IDF's with 32 vents or 28 vents. I have some longer runner intakes and the other carbs so it's just a matter of experimenting I guess. 2.0L Bus piston Web 86B portmatch intake and exhaust ports. 13lb flywheel Bursch SSI Car weighs 1965 lbs 205/50-15 Kumho V700 R tires. Thought of playing with spacers under the carbs to get more length and maybe spacer under the common length velocity stack. Looking for more torque down lower to pull harder exiting the apex of tight AX turns. Whose got the experience of really been there done that? great gains or don't bother. |
Joe Ricard |
Well the butt dyno tells me I have more torque lower in the RPM range. Intake difference is 1" longer and smaller opening at the 44 IDF carb. from 50mm short intake to 46mm long intake.
Throttle response is Much quicker. Enough to make me say DAMN!!!! that's cool. Pulls much harder on my favorite on ramp hit the freeway at 90 something MPH 4th gear. Never did that before. Real test will be this weekend next A/X event should see the top of 3rd gear now. |
Lo-Fi Version | Time is now: 12th July 2025 - 04:03 PM |
