914-6 Oil line fittings, What Degree fitting where? |
Kerrys914 |
May 31 2005, 08:18 AM
Dear, the parts I just sold paid for that part ;) Group: Members Posts: 1,568 Joined: 26-December 02 From: Williamsburg, VA Member No.: 16 |
I have AN-12 fittings at the four connection points for the two hoses.
What degree fittings are needed at each connection? I am going to buy the fittings and hose to make my own hoses. I will need to test fit the engine to get the correct length of each hose. IIRC - 0 Deg for the lower tank - 45 Deg for the Upper tank - 90 For the engine block - 45 Deg for the oil cooler (I have a AN-12 90 Deg welded to the OEM cooler) Cheers and any sources for the above would be cool too (IMG:http://www.914world.com/bbs2/html/emoticons/beerchug.gif) |
Joe Bob |
May 31 2005, 08:33 AM
Retired admin, banned a few times Group: Members Posts: 17,427 Joined: 24-December 02 From: Boulder CO Member No.: 5 Region Association: None |
BAT Inc. (MOCAL) or Pegasus for the fittings. Unless you have an AN tank, you will need adapters from Porsche 30mm to -12AN.
Lo-Fi Version | Time is now: 11th June 2024 - 10:41 PM |
