914-6 Oil line fittings, What Degree fitting where? |
Kerrys914 |
May 31 2005, 08:18 AM
Dear, the parts I just sold paid for that part ;) Group: Members Posts: 1,568 Joined: 26-December 02 From: Williamsburg, VA Member No.: 16 |
I have AN-12 fittings at the four connection points for the two hoses.
What degree fittings are needed at each connection? I am going to buy the fittings and hose to make my own hoses. I will need to test fit the engine to get the correct length of each hose. IIRC - 0 Deg for the lower tank - 45 Deg for the Upper tank - 90 For the engine block - 45 Deg for the oil cooler (I have a AN-12 90 Deg welded to the OEM cooler) Cheers and any sources for the above would be cool too (IMG:http://www.914world.com/bbs2/html/emoticons/beerchug.gif) |
J P Stein |
May 31 2005, 09:23 AM
Irrelevant old fart Group: Members Posts: 8,797 Joined: 30-December 02 From: Vancouver, WA Member No.: 45 Region Association: None |
Summit or Racers Warehouse (Wholesale?) for fittings & hose.
For the attachment at the oil cooler, a straight ought to do it (if your attachment points straight forward.) At the scavenge side (on the pass side), I ran a 90 deg aft then looped it around 180 deg & ran fwd. It gets "busy" trying to go fwd at the scavenge fitting....and don't use "hard" 90 deg fittings. Here's a "soft" 90 deg jobbie at the scavenge side. Edit: eewww, that's an "Andy" pic. (IMG:http://www.914world.com/bbs2/html/emoticons/laugh.gif) Attached thumbnail(s) |
Lo-Fi Version | Time is now: 11th June 2024 - 01:31 PM |
