> 911 to 914/6 engine harness
echocanyons
post Jun 3 2005, 08:05 PM
I have a 81 3/.0 six cyl engine and I want to use it in my 74 914.
What all does the stock main engine wiring harness connect to?
What are the basic things I need the harness to connect to?
Alternator
Starter
VR
Coil/Ignition
Trekkor
post Jun 3 2005, 09:35 PM
I do things...
Since no one else has replied, I'll give it a try.
Use a internally regulated alternator and the wires go right into the stock relay board.
The starter and coil/ignition are the same.
You'll *want* to wire it all nice and tidy through a Pertronix and MSD 6AL box, though... (IMG:http://www.914world.com/bbs2/html/emoticons/mueba.gif)
If you are running carbs, you can take "key on" power off the no longer used terminal from the F.I. harness, also on the relay board.
Using F.I.- (IMG:http://www.914world.com/bbs2/html/emoticons/confused24.gif)
KT
echocanyons   911 to 914/6 engine harness   Jun 3 2005, 08:05 PM
trekkor   Since no one else has replied, I'll give it a ...   Jun 3 2005, 09:35 PM
echocanyons   Thanks Trekkor Well I am still debating on going t...   Jun 3 2005, 09:49 PM
!   You can lose the relay board.....you will need a w...   Jun 3 2005, 10:09 PM
trekkor   If I get another motor someday...   Jun 3 2005, 10:27 PM
jim912928   I see them often on ebay (engine wiring harnesses)...   Jun 4 2005, 08:05 AM
echocanyons   Just out bid...   Jun 4 2005, 11:46 AM
- Lo-Fi Version Time is now: 1st July 2025 - 07:23 AM
