Access to the 75 ignition switch,, Replacing the electric switch part?? |
94teener |
Jun 3 2005, 02:11 PM
Member Group: Members Posts: 209 Joined: 6-February 04 From: Jacksonville, FL Member No.: 1,636 |
I have replaced many a ignition switch on earlier models but never a 75 or 76. Found out today that it ain't like my 74 cars.
I have the wheel, turn sig. & wiper switches removed. Figured out how to get the mechanical switch out but do not know how in the heck to gain access and removal/replacement of the electrical part of the switch. Any help would be greatly appreciated. 94teener, Phil |
eeyore |
Jun 3 2005, 09:39 PM
Senior Member Group: Members Posts: 889 Joined: 8-January 04 From: meridian, id Member No.: 1,533 Region Association: None |
Once you have the wheel off, and pull the allen head bolt from underneath, at 7 o'clock on the left side, you should be able to slide the entire contraption off of the steering column and shaft. You don't need to undo the circlip that hold the bearing on the shaft.
Lo-Fi Version | Time is now: 2nd June 2024 - 11:32 PM |
