Jul 10 2003, 01:08 PM
Group: Posts: 0 Joined: -- Member No.: 0 |
I am going to pull my engine this week after an embarassing weekend at sears point. Too little horsepower. Can't even keep up with the 944's. I hope to build up my 2.0L into something pretty strong, probably in the 140hp range. I will be keeping the stock FI if I can, but if I can sell the stock FI, maybe I go carbs? (IMG:style_emoticons/default/smilie_flagge24.gif)
Where should I start? What should I get? I do have a budget, so I want to keep the costs somewhat moderate. Help me out. Thanks! Terrance (IMG:style_emoticons/default/MDB2.gif) |
| cgnj |
Jul 13 2003, 07:27 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 703 Joined: 6-March 03 From: Medford, NJ Member No.: 403 Region Association: None
Paul.
Building it myself with my 13 year old son. (he probably has dreams of torque wrenchs chasing him). Would I do it again? Qualified yes. If my car had been fuel injected, I would have just done 2055. I already had a set of Dellorto 45's and no FI parts for my car, but I would do it differently. I would try Demello or DPR for the crank. Save about $200 I'd use KB 96's instead of JE. Another $200. These weren't available in stoker pin locations with 22mm pins when I started. I cleared my rods individually, off of the crank. Today I would just clear one on the crank (#2 or #4) and take them to the machined to match. Ended up doing that anyway, just wasted a whole lot of time. I used the Shadek pump. It cost $130 to machine it to work. Raby sells a type 1 pump ready to go. Would I build another one? No. Project will have a six. QUOTE How would I go about raising the compression? Just get the heads decked? If it's being stoked, your'll need spacers just to keep the pistons in the jugs. Carlos 76 2270 'it's almost ready' 76 Project |
L8Apex Build me a Strong 4! Jul 10 2003, 01:08 PM
URY914 go to the the typeIV section of the shoptalkforums... Jul 10 2003, 01:21 PM
thesey914 Paul, you have a big four, yes? what's the spe... Jul 10 2003, 01:28 PM
Brad Roberts Paul,
why would you send him away from here ?? So... Jul 10 2003, 01:35 PM
Qarl Are you trying to keep in the 2.0L displacement, o... Jul 10 2003, 01:45 PM
Qarl Paul has a 1.7 with a big bore (1.9?), racing exha... Jul 10 2003, 01:47 PM
Brad Roberts He just built this current engine...
B Jul 10 2003, 01:48 PM
Andyrew Maybe your thinking of building a strong motor fro... Jul 10 2003, 01:53 PM
Bruce Allert I finally found a 2.0. I'd like to bump it up ... Jul 10 2003, 02:04 PM
Qarl Bruce... from what I read either European P&Cs (hi... Jul 10 2003, 02:06 PM
thesey914 Terry, I reckon realistically you will have to dit... Jul 10 2003, 02:21 PM
L8Apex haha. Brad, I think I did a 2:16 my fastest. yes... Jul 10 2003, 03:06 PM
nomore4 I think Raby uses Headflowmasters for his head wor... Jul 10 2003, 03:28 PM
Bleyseng You can get it close to 120hp with the Djet.
96mm ... Jul 10 2003, 03:37 PM
brant Terrance,
depending upon your ultimate goal...
... Jul 10 2003, 03:53 PM
L8Apex Oh how I've heard that quote so many times. ... Jul 10 2003, 04:04 PM
brant I've never been to sears...
but I've raced... Jul 10 2003, 04:14 PM
L8Apex I know i can definately make up more time at the "... Jul 10 2003, 04:53 PM
Mark Henry Here's a couple of nice T4 engines:
http://ww... Jul 10 2003, 05:26 PM
Bleyseng How is your tranny set up?? maybe thats the ticket... Jul 10 2003, 05:32 PM
Andyrew How is your suspension tuned? What kind of tires? ... Jul 10 2003, 05:44 PM
L8Apex Suspension is pretty good. err, Bilsteins all aro... Jul 10 2003, 05:52 PM
Bleyseng You can swap the gears around to get better ratios... Jul 10 2003, 05:55 PM
Tony C 20hp does not = 8 seconds, sorry.
-tony :evilgrin... Jul 10 2003, 06:41 PM
Bleyseng Maybe if he slaps Type R stickers all over the car... Jul 10 2003, 07:17 PM
redshift I added those type R stickers (had to look all ove... Jul 10 2003, 07:27 PM
L8Apex I have no clue what top speeds I am hitting. speed... Jul 10 2003, 07:38 PM
Jeff Krieger Save up your money and buy one of these . Jul 10 2003, 08:25 PM
L8Apex I am leaning towards carbs now after some research... Jul 10 2003, 09:10 PM
Bleyseng Throwing on carbs on a motor that has a stock FI c... Jul 10 2003, 09:15 PM
L8Apex I'm definately going to get a new cam. Probab... Jul 10 2003, 09:32 PM
cha914 Do you have to stay 2.0L for your class or can you... Jul 10 2003, 10:04 PM
campbellcj
jkeyzer Buy one of Raby's engines and sell me your 2.0... Jul 10 2003, 11:43 PM
L8Apex WoW, thanks for the help. Let's keep this thr... Jul 11 2003, 12:25 AM
seanery Read webcam's info on cams. They give a pretty... Jul 11 2003, 12:10 PM
seanery Here it is:
cam talk Jul 11 2003, 12:12 PM
Jeff Krieger
cha914 Cbperformance has the whole kit, new carbs, new ma... Jul 11 2003, 12:46 PM
L8Apex I want to keep it under 2.2 to meet PCA rules ( I ... Jul 11 2003, 01:01 PM
J P Stein
Why are you limited to 2.2L when 944s are at leas... Jul 11 2003, 01:01 PM
Qarl L8apex...
Don't rush anything.
Plan out your... Jul 11 2003, 01:17 PM
DNHunt I'm checking into some of this now. It sure se... Jul 11 2003, 04:11 PM
Brad Roberts Yep.. convert the car to a six.
Why spend 7k on a... Jul 11 2003, 04:15 PM
L8Apex yeah, the 6 conversion is definately one of the ch... Jul 11 2003, 04:27 PM
DNHunt How do you explain stubborn. My car was made a fou... Jul 11 2003, 04:31 PM
Brad Roberts Play your cards correctly and you can convert a 4c... Jul 11 2003, 04:33 PM
Brad Roberts Nothing wrong with the fours... I just know what g... Jul 11 2003, 04:38 PM
Andyrew Jeff, 944's are 900 pounds more than us.. and ... Jul 11 2003, 04:48 PM
L8Apex I will whine as much as I can :worship:
But I ma... Jul 11 2003, 05:10 PM
campbellcj The comment about always being ready to jump on -6... Jul 11 2003, 11:20 PM
L8Apex With my budget, I have settled on building the 4 f... Jul 12 2003, 02:19 PM
cgnj Hi,
76x96
Based on building my 2270, you may not h... Jul 12 2003, 05:21 PM
URY914 CGNJ,
So you think you wouldn't need to clear... Jul 12 2003, 06:04 PM
Brad Roberts Hum..
I have 2 2270 engines with NO clearancing.... Jul 12 2003, 06:06 PM
URY914 Damn, now I'm back to a 2270...
But who as a ... Jul 12 2003, 06:10 PM
Brad Roberts I think the 2270 would ideal for your car.
I thin... Jul 12 2003, 06:12 PM
URY914 BTW,
I've had to revise some of my fiberglass ... Jul 12 2003, 06:25 PM
L8Apex What's with This Setup?
I am still pretty los... Jul 12 2003, 08:04 PM
URY914 I think thats a type 1 kit.
Won't work. Jul 12 2003, 10:28 PM
my15window I'm from O.C.Cal, home of most all the aircool... Jul 12 2003, 11:10 PM
cha914 You should probably go hang out at www.shoptalkfo... Jul 12 2003, 11:17 PM
DNHunt Carlos
How did it go with your son? One of the ma... Jul 13 2003, 07:40 AM
anthony I think it would depend a lot on your kid's te... Jul 13 2003, 02:01 PM
Bleyseng Blair has hung around me while I worked on cars si... Jul 13 2003, 02:22 PM
Bruce Allert Wow! you guys are cool.... Wished my Dad would... Jul 13 2003, 08:27 PM
Rouser In 1972, my "father" (he ceased being my "Pops" af... Jul 14 2003, 09:04 PM
anthony Consider yourself lucky you got the bug! At le... Jul 15 2003, 01:11 AM
Rouser Actually, he did pretty good.
Since he wasn't... Jul 15 2003, 05:54 PM
DNHunt Rouser
I was worried there but I quess I'm sa... Jul 15 2003, 08:22 PM
Qarl L8Apex:
1300 views and 70 replies later.... what ... Jul 16 2003, 08:44 AM
L8Apex haha! damn, I am very very stumped. I was th... Jul 16 2003, 03:53 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 11:05 AM |
