some ideas for oil-cooling and brake air ducts ... |
SirAndy |
Feb 5 2003, 03:06 PM
Resident German Group: Admin Posts: 41,681 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
after a short brainstorm session with Roger Sheridan, brad and jason i've been busy bouncing around ideas about a good oil-cooling system and getting some air to my front brakes.
here's what i came up with so far: Oil-Cooling: my first idea was to just put a oil cooler in the front. i have a GT (916) front spoiler that already has the cutout for the cooler. but then, while looking at rogers car, i got a better idea. what if i put a oil cooler in the spot where the stock fresh air fan resides? this is a high pressure area (roger uses it as air intake for his tranny-cooler). i can then use tubes to run the air from the oil-cooler either inside the car (meaning i can have heat AND nice headers) or route it to the outside. the fans you see in the picture could be just 911 ventilation fans. using fans would also help cooling the car when i sit in traffic, which a normal front oilcooler does not do very well. any commentz? (IMG:http://www.sirandy.com/pix/914/ideas/oilcooling.jpg) Brake Air Duct: since i already have the above mentioned 916 front spoiler and it does not come with openings for brake cooling, i now can use the oilcooler cutout to run a tube (or duct) throught the sides of the front trunk and route the air to the brakes. any commentz? (IMG:http://www.sirandy.com/pix/914/ideas/brakeairduct.jpg) |
Jeroen |
Feb 5 2003, 04:16 PM
914 Guru Group: Members Posts: 7,887 Joined: 24-December 02 From: The Netherlands Member No.: 3 Region Association: Europe |
hey andy,
cut some inlets for the brake ducts in the very bottom of that 916 bumper/spoiler, about under the foglights it would be very hard to spot these (unless you're laying down) Cover the openings with a stretched mesh painted in body color and you'll notice em even less this way, you can put the oilcooler in the nose cheers, jeroen |
Lo-Fi Version | Time is now: 11th June 2024 - 06:46 PM |
