Clutch/accelerator cable set-up, How much free play? |
ChrisReale |
Jul 13 2003, 07:14 PM
Sleazy Group: Members Posts: 2,665 Joined: 20-January 03 From: San Francisco Member No.: 176 |
When tightening your clutch cable, how much free play do you want in the pedal? When adjusting the acc. cable at the throttle body, how loose should it be? When I had my acc. cable too tight, I would push the clutch in, and the rpm's would shoot up. So, what is the right set up?
SirAndy |
Jul 13 2003, 10:44 PM
Resident German Group: Admin Posts: 41,669 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
QUOTE(ChrisReale @ Jul 13 2003, 06:14 PM) When I had my acc. cable too tight, I would push the clutch in, and the rpm's would shoot up. So, what is the right set up? sounds like your 2 cables are wrapped around each other. no matter how tight your accel cable is, the clutch should never effect your rpm ... check the front center tunnel, where the clutch cable comes out of the tube and see if the accel cable is wrapped around it. later, Andy |
Lo-Fi Version | Time is now: 3rd June 2024 - 08:59 AM |
