how vital is this whole shimming the, flywheel thing? |
xsboost90 |
Jun 7 2005, 06:36 AM
Senior Member Group: Members Posts: 1,393 Joined: 2-August 04 From: cincinnati Member No.: 2,432 |
talking to the guy i bought the motor from the other day, and he asked how many shims i had to put in the flywheel. I said..." shims?". When i bolted and torqued it 80lbs, i didnt see anything about no shims! Engine seemed to turn over by hand, alittle stiff, but turned over none the less. Could i be hurting it running w/ too much tension or something? Im planning on taking the trans back out for some parts replacement, i guess ill mic it then and check, but if its too tight could it toast the motor i guess? (IMG:http://www.914world.com/bbs2/html/emoticons/confused24.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/headbang.gif)
jhadler |
Jun 7 2005, 04:17 PM
Long term tinkerer... Group: Members Posts: 1,879 Joined: 7-April 03 From: Lyons, CO Member No.: 529 |
Get a dial indicator!! Measure the endplay! And use those shims (yup, three is the number, something to do with getting oil in there or something...).
No enough endplay (too tight) will burn up the bearing. Which will lead to too much endplay, and then your crank will go -boom-. Yup, Been There Done That. -ouch- A number of years ago I had replaced the flywheel and reset the endplay. I needed to use the three thickest shims I could get to set it right. That -should- have told me something at the time... 8 months later... -Josh2 |
Lo-Fi Version | Time is now: 29th May 2024 - 02:46 AM |
