| solex |
May 16 2005, 09:27 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 789 Joined: 12-January 05 From: Long Island, NY Member No.: 3,439 Region Association: North East States |
Hello All,
I have recently replaced all of the flexible brake lines, pads and rotors. The MC seems to be realtively new and the calipers all function. After all of this work, I am still unimpressed with the brakes on this car. I have read the pelican article regarding the front caliper 320i upgrade. The article also suggest that the brakes in the 914-4 are not that good. No matter how hard I try I cannot lock up the fronts. Anyone who has done this upgrade care to comment? Does it make a significant difference? Thanks, Dan |
| solex |
Jun 8 2005, 07:02 AM
The saga continues...
I reset the venting clearence to .004" which reduced the pedal travel. I decided to go out for a long drive. It was very hot out probably 90 degrees on the Northern State, the brakes again better but not impressive. About 20 minutes into the drive on the Northern State in traffic (what else is new). I stepped on the brake pedal and it almost went to the floor but did not trigger the dash light. The pedal felt this way for a few minutes. I though perhaps the heat may have something to do with it so I pulled off and drove at a moderate speed and the pedal came back to it usual possition. After getting home I noticed that the fluid resovior had overflowed through the cap. Is this an indication of something wrong with the MC? Thanks, Dan |
solex Brakes, Brakes, Brakes May 16 2005, 09:27 AM
914GT I've got the 320i brakes and replaced the prop... May 16 2005, 09:51 AM
TROJANMAN i know there is debate on this issue, but i was to... May 16 2005, 09:55 AM
Cap'n Krusty And why, pray tell, would you want to lock up your... May 16 2005, 10:13 AM
davep http://www.914world.com/bbs2/h... May 16 2005, 10:23 AM
solex Cap'n
I was using the phrase "lock up" to co... May 16 2005, 10:25 AM
jwalters http://www.914world.com/bbs2/html/... May 16 2005, 10:26 AM
jwalters May 16 2005, 10:29 AM
solex J,
Thanks for the reply, I have bled the brakes m... May 16 2005, 10:30 AM
Brando May 16 2005, 10:32 AM
! I will add my $.02, if I may....you have a 30... May 16 2005, 10:34 AM
jwalters May 16 2005, 10:34 AM
Mueller May 16 2005, 10:35 AM
jwalters http://www.914world.com/bbs2/html/e... May 16 2005, 10:36 AM
jwalters Man, mine flexed like a cicus performer---but beca... May 16 2005, 10:38 AM
solex J, Mueller,
Tires are shit but have decent tread,... May 16 2005, 10:43 AM
jwalters http://www.914world.com/bbs2/htm... May 16 2005, 10:46 AM
Brando May 16 2005, 10:59 AM
davep ... May 16 2005, 11:57 AM
jwalters May 16 2005, 12:03 PM
Air_Cooled_Nut Okay, motorcycles, cars & trucks should ALL be abl... May 16 2005, 09:52 PM
trekkor
