how vital is this whole shimming the, flywheel thing? |
xsboost90 |
Jun 7 2005, 06:36 AM
Senior Member Group: Members Posts: 1,393 Joined: 2-August 04 From: cincinnati Member No.: 2,432 |
talking to the guy i bought the motor from the other day, and he asked how many shims i had to put in the flywheel. I said..." shims?". When i bolted and torqued it 80lbs, i didnt see anything about no shims! Engine seemed to turn over by hand, alittle stiff, but turned over none the less. Could i be hurting it running w/ too much tension or something? Im planning on taking the trans back out for some parts replacement, i guess ill mic it then and check, but if its too tight could it toast the motor i guess? (IMG:http://www.914world.com/bbs2/html/emoticons/confused24.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/headbang.gif)
tat2dphreak |
Jun 8 2005, 08:02 AM
stoya, stoya, stoya Group: Benefactors Posts: 8,797 Joined: 6-June 03 From: Wylie, TX Member No.: 792 Region Association: Southwest Region |
yea I was afraid of that... I didn't use any... I've only ran the engine for a little bit, and not under any load(on jackstands only) ... so hopefully it's ok... one more thing to do before running it... damn! oh well, it will give me an excuse to pull the engine and run new fuel lines for good measure... anything else? where can I get a dial indicator that won't kill my pocketbook? do I need to replace the flywheel blots, crush washer and all those other things I changed last year when I installed the engine? I'm glad this was caught now... and don't want to F something else up... |
Lo-Fi Version | Time is now: 4th June 2024 - 01:15 PM |
