DIS on a type IV, Well this got me revved up |
DNHunt |
Jul 13 2003, 09:30 PM
914 Wizard? No way. I got too much to learn. Group: Members Posts: 4,099 Joined: 21-April 03 From: Gig Harbor, WA Member No.: 598 |
The next incarnation of MegaSquirt, ULTRAMEGASQUIRT is going to have onboard DIS and a driver for the Bosch LS4u wideband 02 sensor. The whole package on 1 board. I can hardly wait. Imagine no more worrying about a dirty dizzy, springs, putting oil on the felt, vacuum advance. Time it once and forget about it (course that one time is gonna be b***h). Run better gas and a hotter chip for the track with a little more advance.
The whole system will use real automotive connectors, no more DB 37 pin connectors. Sounds like the little kid on the block is growing up. Anyone have a crank trigger on their 4? The only spot I can see for one is replacing the spacing washer behind the fan with a machined trigger wheel. It appears that you could mount the sensor off the studs that attach the oil cooler This is gonna be one long winter. I got a s**tload of things to do. Dave |
Mark Henry |
Jul 14 2003, 05:26 PM
SDS says that they have only had one reported failure of the crank trigger that was fault of the sensor and they haven’t used that type (brand) since the mid ‘90’s. They have had many a trigger wrecked by improper installation.
I think the SDS trigger would be next to imposable to mount on the flywheel. The sensors are mounted in a 1 ½ X 2 inch aluminum plate. It runs off of three magnets, two triggers and one sync magnet. The big one is you have to time it with a strobe to get the base line in the computer. I think that I will start and time the engine on the floor then do the install. I just think that it will be easier. I’m hoping that I can go at the install this weekend. As long as all goes well this week at the ol’ grind. (IMG:style_emoticons/default/smash.gif) |
Lo-Fi Version | Time is now: 6th June 2024 - 09:16 AM |
