> Charging Problem Revisited, Everything Swapped
Allan
post Jun 10 2005, 04:10 PM
Teenerless Weenie
Okay, been having a charging problem for awhile now. Started replacing and checking over everything. So far I've replaced the voltage regulator, relay board and now finally replaced the alternator and harness. Guess what??? No freaking charge to the battery. (IMG:http://www.914world.com/bbs2/html/emoticons/headbang.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/headbang.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/headbang.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/headbang.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/headbang.gif)
Any ideas????????????????????????
Headrage   Charging Problem Revisited   Jun 10 2005, 04:10 PM
ArtechnikA   didn't see the generator bulb in the dash inst...   Jun 10 2005, 04:19 PM
Headrage   I've never replaced the bulb. It's the on...   Jun 10 2005, 04:21 PM
lapuwali   If the G light doesn't come on when you switch...   Jun 10 2005, 04:25 PM
skline   The light stays lit the entire time the car is run...   Jun 10 2005, 04:26 PM
lapuwali   Could be the "new" VR is also bad. This apparentl...   Jun 10 2005, 04:58 PM
Headrage   Here's the deal, everything has been tested an...   Jun 10 2005, 09:02 PM
lapuwali   Yes, if the G lamp wire is shorted to ground betwe...   Jun 10 2005, 09:27 PM
GWN7   Hey I was right about the bulb.....sorry nothing e...   Jun 10 2005, 10:12 PM
Headrage   Well, for some reason my charging system is funct...   Jun 12 2005, 07:42 PM
redshift   -checks watch- -drops hand- http:...   Jun 12 2005, 07:55 PM
Headrage   ...   Jun 13 2005, 10:06 PM
GWN7   Check the part of the car that you kicked in frust...   Jun 13 2005, 10:20 PM
Joe Sharp   Allan: The only reason I can do an alt. exchange i...   Jun 13 2005, 10:35 PM
Aaron Cox
- Lo-Fi Version Time is now: 6th July 2025 - 09:16 PM
