jim912928 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,487 Joined: 8-January 04 From: Granger, IN Member No.: 1,536 Region Association: Upper MidWest ![]() |
Well, this was a pain in the arse. I started at 4pm hoping it would take about 2 hours...finished at 10pm (ok, 1 trip to the hardware store for some washers....ate dinner). Using the open end wrench to put the top seal on was easy...but the angle didn't work for the bottom..that one took about 30 minutes to get in there and finally used a hack saw blade with grease. And getting to that blind nut...what a pain!
Anyhow..it's all back together and I couldn't find any info on tightening specs in the factory manuals...so the blind nut (I assume this is just to keep the cooler stationary) I tightened up tight using a tiny wratchet...and the two nuts over the seals i tightened with a small wrench just till I felt hard resistence using one finger to push the wrench up with. Was that good enough? Hopefully I leak less now. The new seals didn't look exactly like the old ones. The ones in there seemed to have a larger edge on one side versus the other. The new ones looked the same on both sides. Anyhow...how tight should those seal nuts be? |
joeav8tor |
Member ![]() ![]() Group: Members Posts: 408 Joined: 23-January 05 From: mattituck, Long Island NY Member No.: 3,493 ![]() |
I just replaced my oil cooler seals for the heck of it when the engine was out of the car..a lot easier this way...you want to tighten the bolts tight enough so there isnt a leak, but not too tight to crush the seals...I know this sound tough...I originally saw oil at the bottom of my oil cooler, but found that my pressure switch had oil leaking from it, so I replaced it...I just replaced the oil cooler seals, pushrod tube seals because the engine was out of the car...it is a good idea to change the pressure switch...which is just south of the dizzy.
Joe (IMG:http://www.914world.com/bbs2/html/emoticons/flag.gif) |
Lo-Fi Version | Time is now: 23rd September 2025 - 12:31 AM |
