| mistro |
Jun 14 2005, 11:48 PM
Member ![]() ![]() Group: Members Posts: 148 Joined: 12-March 04 From: Highland Park, IL Member No.: 1,786 Region Association: None |
Tomorrow I need to take off my rockers to get them reshot at the local auto body shop since the 0 degree weather we had in January (even in my garage) caused the paint to peel. And I want to see what is behind them and clean there. A couple of questions:
1. Drilling out the rivets, what diameter drill bit do I use? 2. Any other issues with removal of the rockers? 3. I remember reading here that the original paint for the rockers is a mix of 30 flat and 70 gloss black, is this correct? 4. What are the length of the rivets for reinstallation? 5. Any idea where i can find black rivets? Sears only sells gray aluminum ones. I'll post pictures tomorrow. TIA. Rgds, Michael |
| mistro |
Jun 15 2005, 02:04 PM
Remil, First off thanks for responding. Secondly so I assume the length of the rivet is not critical? Thirdly with the second post which list those plastic removable rivets, do you think one of these three would work? TIA. Rgds, Michael
Tuflok ® The Tuflok® is a one-piece fastener with a pre-driven pin that is quickly installed by hand or with automatic equipment. It is ideally suited for any application requiring a front mount, removable, reusable push-type plastic rivet where a dependable vibration-resistant panel fastener is essential. Screw Type Tuflok ® This variation of the TufLok® allows the fastener to be inserted by pushing in the pin and removed by unscrewing it. The screw type Tuflok® is available in a wide variety of panel thickness hole sizes and head configurations. Micro-Tuflok® This one-piece fastener is ideally suited for fastening electronic components to printed circuit boards, mounting cooling fans to computer chassis / electrical boxes and finger guards to cooling fans. Molded in a durable, heat stabilized, impact modified nylon material, this unique design allows the part to draw panels together as a screw would, and hold the panels tightly to each other. |
mistro Rockers off tomorrow Jun 14 2005, 11:48 PM
sj914 Those rivets along the top are actually plastic ri... Jun 15 2005, 02:53 AM
mistro All
[/QUOTE] Those rivets along the top are actual... Jun 15 2005, 07:24 AM
sj914 I've never really tried to salvage them. The ... Jun 15 2005, 07:42 AM
mistro Thanks Remile, Couldn't find on ebay. Do you k... Jun 15 2005, 11:50 AM
sj914 I'm not sure of the length of the rivets. Eve... Jun 15 2005, 12:15 PM
sj914 You might want to also check out this company for ... Jun 15 2005, 12:21 PM
sj914 I would use the screw type tuflok because cleaning... Jun 15 2005, 02:08 PM
mistro Remil, Agreed on the screw type, that's why I ... Jun 15 2005, 02:16 PM
itsa914 Check this past thread about rockers & rivets
HER... Jun 15 2005, 02:31 PM
mistro Rockers off, absolutely no damage or rust. Rockers... Jun 15 2005, 07:47 PM
mistro Anybody know the factory stock paint for the rocke... Jun 16 2005, 09:15 AM
mistro http://www.914world.com/bbs2/ht... Jun 16 2005, 09:04 PM
sj914 I think you can get a close match with wurth paint... Jun 17 2005, 01:19 AM
qa1142 Brad mayer at 914ltd has the correct rivits
Lo-Fi Version | Time is now: 7th December 2025 - 07:27 PM |
