> Dist advance?, where to hook up....
xsboost90
post Jun 16 2005, 05:51 AM
ok, so the trans is back in and she is shifting much nicer now, but im noticing a slight hesitation along the acceleration. I remember the vac line for the dist is still connected to the charcoal canister temporarily. Now there are two vac lines on the dist, one closer to the base of the dist, im guessing this would RETARD the timing, the other on the outside of the diaphram, which would ADVANCE the timing correct? Factory says to put the hose on the retard line but this makes my car knock and ping like crazy! I have never really heard a clear answer weather to leave the VAC off, or where to run it to, how it works etc. I tried but cant find any clear info on this. I think i need a mallory dizzy... (IMG:http://www.914world.com/bbs2/html/emoticons/dry.gif)
bd1308
post Jun 16 2005, 06:04 AM
Sir Post-a-lot
some were actually disconnected from the factory. Mine is....I just plain didnt have a hookup. now my retard is connected and that helps with accel. where did you hook the advance anyway? the connection to the throttle body goes to the retard and will mess things up if you hook that to the advance side of the unit.
xsboost90   Dist advance?   Jun 16 2005, 05:51 AM
bd1308   some were actually disconnected from the factory. ...   Jun 16 2005, 06:04 AM
xsboost90   my car doesnt have the hookup for a second hose to...   Jun 16 2005, 06:14 AM
bd1308   okay that one must must must go to the retard side...   Jun 16 2005, 06:18 AM
xsboost90   really it pings WORSE when i hook it up to the ret...   Jun 16 2005, 06:23 AM
Gint   Britt giving dizzy advice... h...   Jun 16 2005, 07:08 AM
Bleyseng   Nah, it just means you have to retime it. Time it ...   Jun 16 2005, 07:10 AM
Gint   ...   Jun 16 2005, 07:12 AM
xsboost90   ive done the 3500 timing w/ hoses off twice to dou...   Jun 16 2005, 08:07 AM
Dave_Darling   Plug in the hose to the retard fitting, as stated-...   Jun 16 2005, 11:03 AM
xsboost90   ok, i admit it, im a dumkopf. Advanced the optic e...   Jun 16 2005, 11:07 AM
Dave_Darling   Sounds like you were setting the timing incorrectl...   Jun 16 2005, 11:52 AM
Demick     Jun 16 2005, 12:36 PM
Gint   Good point since there's no vacuum on that por...   Jun 16 2005, 03:12 PM
bd1308   just wait Gint until I get my motor back in.   Jun 16 2005, 03:18 PM
Gint   Whaddyagonnado? Time it to death?
- Lo-Fi Version Time is now: 1st August 2025 - 02:57 AM
