xsboost90 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,393 Joined: 2-August 04 From: cincinnati Member No.: 2,432 ![]() |
ok, so the trans is back in and she is shifting much nicer now, but im noticing a slight hesitation along the acceleration. I remember the vac line for the dist is still connected to the charcoal canister temporarily. Now there are two vac lines on the dist, one closer to the base of the dist, im guessing this would RETARD the timing, the other on the outside of the diaphram, which would ADVANCE the timing correct? Factory says to put the hose on the retard line but this makes my car knock and ping like crazy! I have never really heard a clear answer weather to leave the VAC off, or where to run it to, how it works etc. I tried but cant find any clear info on this. I think i need a mallory dizzy... (IMG:http://www.914world.com/bbs2/html/emoticons/dry.gif)
bd1308 |
Sir Post-a-lot ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,020 Joined: 24-January 05 From: Louisville,KY Member No.: 3,501 ![]() |
okay that one must must must go to the retard side. the vac reatrd will improve acceleration. I plugged it in after x years unplugged and i almost pissed myself....i was fast. the retard recieves vac at idle, the advance does not. since you plugged in the reatrd connection to the advance side of the dizzy....thats why its pinging and stuff.
Lo-Fi Version | Time is now: 1st August 2025 - 02:57 AM |
