> Hell Hole Repair made easy, Well, easier anyway.
skline
post Jun 17 2005, 04:53 PM
Born to Drive
Ok, Today at sklines garage we explore repairing the hell hole in a slightly rusty car. As some of you know, Mark Bland (Engman) has been working on a new Hell Hole repair kit. This is my redition of removing the rust and installing this kit. My first step is to remove the battery tray and support. I did so with my trusty $5.00 air chisel. The next step in to clean the area as good as you can and remove as much loose rust and get down to a point that you can weld. Next I will be fitting the kit into place for fittment. I will be posting pictures as I go. I just started and at this point, I have removed the battery tray and cleaned the hole out. Now I am going to fit the kit into place to see how it fits. Aaron has beent he photographer so dont blame me for bad pictures. If I have any question about it I will take some also. (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif) Off to work now, I will post the pictures later.
skline
post Jun 18 2005, 10:06 AM
Born to Drive
QUOTE (rhodyguy @ Jun 18 2005, 08:37 AM)
how are you going to address the chanel for the engine seal on the shelve scott?
k
Actually, the kit doesnt replace that channel where the rubber goes, it gets welded on top of that. The rubber of course will have to be removed and replaced as it will melt from welding and this car is getting a V8 conversion so it will not be replaced. I tried to remove the old rubber but it wouldnt budge so I figure it will get nice and soft when I weld that piece in and be much more pliable when I am done. I didnt get it finished last night but will try to get it done today. This car was not very rusted and the kit is designed to repair a more seriously rusted car so I had to do some trimming to get some of the pieces to fit in. This is the first one I have done so in my opinion it is not as clean as it could have been, I am still learing what I should do with each piece as I go and figuring out that I should have done a few things differently. It's a learning curve. Alberto has one that is more in line for what this kit was made for and I am sure it will come out much nicer than this one. After I started welding in the piece on the side to cover the tray area, I realized the metal wouldnt really shape the way I wanted it to as I had already welded in where it would need to flex. So I had to cut a slit in it and then beat it into place and then weld around the cut. Fortunately the metal behind was still very strong and didnt need to be repaired. You will see what I mean. This is welded in but only tacked in a few place, I will finish it later today.
skline   Hell Hole Repair made easy   Jun 17 2005, 04:53 PM
skline   Here are a few of the starting out pictures   Jun 17 2005, 04:58 PM
skline   Next   Jun 17 2005, 04:59 PM
skline   Tray out   Jun 17 2005, 05:00 PM
skline   Outfitted for sandblasting   Jun 17 2005, 05:01 PM
skline   Getting into the work   Jun 17 2005, 05:02 PM
spunone   JUST HOPE YOU DON'T DO TO YOUR 5.00 AIR CHISEL...   Jun 17 2005, 05:03 PM
ChrisReale   Outfitted for sandblasting looks like a SoCal Dart...   Jun 17 2005, 05:05 PM
skline   This is the kit as packaged by Mark, looks cool. H...   Jun 17 2005, 05:08 PM
jet1   It's about time someone put a kit together...   Jun 17 2005, 05:17 PM
Eric_Shea   Hurry up Biatch. Get'er done. Mark won't...   Jun 17 2005, 05:19 PM
sixnotfour     Jun 17 2005, 07:05 PM
CptTripps   If Mark makes it, it's good stuff. this guy do...   Jun 17 2005, 08:17 PM
Dead Air     Jun 17 2005, 08:32 PM
lagunero   ...   Jun 18 2005, 02:05 AM
rhodyguy   how are you going to address the chanel for the en...   Jun 18 2005, 09:37 AM
Eric_Shea
  Jun 18 2005, 09:49 AM
skline   ...   Jun 18 2005, 10:06 AM
skline   Here is a picture of how I left it last night.   Jun 18 2005, 10:10 AM
Engman
  Jun 18 2005, 10:22 AM
Jeff Bonanno   heh   Jun 18 2005, 10:29 AM
Engman   Heh heh - the sand people! M   Jun 18 2005, 10:31 AM
Eric_Shea
  Jun 18 2005, 11:53 AM
rhodyguy   i'm guessing the driverside would be a near mi...   Jun 18 2005, 02:53 PM
Engman
  Jun 19 2005, 05:24 PM
Engman   Here is an outline of what is replaces (thanks Tre...   Jun 19 2005, 11:26 PM
Dead Air   or this?   Jun 20 2005, 05:53 AM
Engman   Some info on the drivers side - the fan mount and ...   Jun 20 2005, 09:16 PM
Eric_Shea   Couple of questions Mark. I'm not looking at ...   Jun 20 2005, 09:37 PM
Engman   Eric, I highly suspect you are correct. Any pics...   Jun 20 2005, 09:48 PM
Hammer920   ya call that a bad battery tray Hmmm mine cant hol...   Jun 20 2005, 09:52 PM
- Lo-Fi Version Time is now: 4th September 2025 - 06:11 AM
