> Hell Hole Repair made easy, Well, easier anyway.
skline
post Jun 17 2005, 04:53 PM
Born to Drive
Ok, Today at sklines garage we explore repairing the hell hole in a slightly rusty car. As some of you know, Mark Bland (Engman) has been working on a new Hell Hole repair kit. This is my redition of removing the rust and installing this kit. My first step is to remove the battery tray and support. I did so with my trusty $5.00 air chisel. The next step in to clean the area as good as you can and remove as much loose rust and get down to a point that you can weld. Next I will be fitting the kit into place for fittment. I will be posting pictures as I go. I just started and at this point, I have removed the battery tray and cleaned the hole out. Now I am going to fit the kit into place to see how it fits. Aaron has beent he photographer so dont blame me for bad pictures. If I have any question about it I will take some also. (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif) Off to work now, I will post the pictures later.
Engman
post Jun 18 2005, 10:22 AM
Zoisite
how are you going to address the chanel for the engine seal on the shelve scott?
Some info on this is in order...
The kit has 4 pieces
1. engine shelf cover - 20g
2. lower font firewall piece - 20g
3. inner wheel house piece - above the long - 20g
4. Top of long - 16g
The idea behind it is to make affordable an alternative to the more expensive (and nicer) replacement panels. You do have to form them either as Scott is doing along with using a vice to put the 90 degree bends into some pieces (all are 20g pieces that get the 90 degree bends).
It is a kit that you will need to make fit correctly for your application - meaning you will/may have to trim some pieces to fit more better (insert smart ass remark here).
The basis for this kit wasTekkor Thread
While this was used as the basis several changes were made to make this fit. The engine shelf has the cutouts for the fuel lines and drain tubes, several pieces were made larger in certain areas to better minic the area I have seen rusted.
Now its a kit - you put the forms in, you trim to fit. These are not drop in pieces - you do have to work them a little to make them fit. If you want drop in pieces - get the RD pieces - these are nice - but you will drop some coin on them.
Later I will post info in the resources section -
M
skline   Hell Hole Repair made easy   Jun 17 2005, 04:53 PM
skline   Here are a few of the starting out pictures   Jun 17 2005, 04:58 PM
skline   Next   Jun 17 2005, 04:59 PM
skline   Tray out   Jun 17 2005, 05:00 PM
skline   Outfitted for sandblasting   Jun 17 2005, 05:01 PM
skline   Getting into the work   Jun 17 2005, 05:02 PM
spunone   JUST HOPE YOU DON'T DO TO YOUR 5.00 AIR CHISEL...   Jun 17 2005, 05:03 PM
ChrisReale   Outfitted for sandblasting looks like a SoCal Dart...   Jun 17 2005, 05:05 PM
skline   This is the kit as packaged by Mark, looks cool. H...   Jun 17 2005, 05:08 PM
jet1   It's about time someone put a kit together...   Jun 17 2005, 05:17 PM
Eric_Shea   Hurry up Biatch. Get'er done. Mark won't...   Jun 17 2005, 05:19 PM
sixnotfour     Jun 17 2005, 07:05 PM
CptTripps   If Mark makes it, it's good stuff. this guy do...   Jun 17 2005, 08:17 PM
Dead Air     Jun 17 2005, 08:32 PM
lagunero   ...   Jun 18 2005, 02:05 AM
rhodyguy   how are you going to address the chanel for the en...   Jun 18 2005, 09:37 AM
Eric_Shea
  Jun 18 2005, 09:49 AM
skline   ...   Jun 18 2005, 10:06 AM
skline   Here is a picture of how I left it last night.   Jun 18 2005, 10:10 AM
Engman
  Jun 18 2005, 10:22 AM Jeff Bonanno   heh   Jun 18 2005, 10:29 AM
Engman   Heh heh - the sand people! M   Jun 18 2005, 10:31 AM
Eric_Shea
  Jun 18 2005, 11:53 AM
rhodyguy   i'm guessing the driverside would be a near mi...   Jun 18 2005, 02:53 PM
Engman
  Jun 19 2005, 05:24 PM
Engman   Here is an outline of what is replaces (thanks Tre...   Jun 19 2005, 11:26 PM
Dead Air   or this?   Jun 20 2005, 05:53 AM
Engman   Some info on the drivers side - the fan mount and ...   Jun 20 2005, 09:16 PM
Eric_Shea   Couple of questions Mark. I'm not looking at ...   Jun 20 2005, 09:37 PM
Engman   Eric, I highly suspect you are correct. Any pics...   Jun 20 2005, 09:48 PM
Hammer920   ya call that a bad battery tray Hmmm mine cant hol...   Jun 20 2005, 09:52 PM
- Lo-Fi Version Time is now: 4th September 2025 - 06:14 AM
