| andys |
Jun 20 2005, 01:52 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,165 Joined: 21-May 03 From: Valencia, CA Member No.: 721 Region Association: None
Though it about time I start a progress thread on some custom trailing arms I am designing and fabricating.
First, a little background: My car is a planned LS1 V8 conversion that will use an Audi/Getrag 6 speed transaxle (which I already have). From this, two things result; 1. The drive flanges are placed wider then on the 914, and are assymetric to the centerline. 2. The drive flanges will require adapters, as the bolt pattern is outside of the CV. The 911 axles I intend on using are shorter than the 914, but not enough to provide room for the flange adapters. The motor/transaxle will be placed off-center in order to get symmetry of the drive flanges. By fabricating the trailing arms, I can accomplish a couple of things. First, I can position the bearing carrier further outboard to get the additional space for the flange adapters. This will also help keep wheel spacers from being so thick. Second, I can use the larger (+5mm dia and 5mm wider) late model 911 bearings, along with the late 911 wheel drive flanges. Third, I can adapt any brake caliper I want, which will be an '89 Carrera to start with since I already have it. It is not my first choice (heavy!!), but it will do for now. I will employ the Wilwood mechanical spot caliper for the parking brake. Fourth, this custom fabrication allows me to create a structural part suitable for V8 power, and yet meet a target weight comparable to a stock trailing arm. Fifth, I can make provision for the pivot shaft bearing of choice. Though I considered the needle bearing setup, I will start off with Weltmeister Polygraphites' (I do have some other polyurethane material that I may try later as well). So why go through all the trouble? Because I can, is my best answer. Being an engineer, I just can't resist! Also, I have the equipment to do all the machining and welding. Now having said that, I don't think I would start a project like this again, considering all the research, design, fabrication, etc.....takes waaay too much time; time I don't really have. Ok, enough of all that! I'm sure you'd rather see the pic's, then read all the blather...... This pic is of some of the parts I've made up so far; Pivot shaft housing, pivot shaft bushings to be welded in, bearing carrier, caliper mount, and the large axle tube. I'll add more parts as we go along: Attached thumbnail(s)
| Terryst1 |
Jun 20 2005, 05:11 PM
Terryst1 ![]() Group: Members Posts: 19 Joined: 7-April 03 Member No.: 533 Region Association: None |
Hi Andy:
I was VERY interested when reading about your custom 914 swing arms! -I also have a 914-V8 and have had rear bearing failures and would love to go to a bigger bearing. -I question the strength of the original unit that was designed for 100 HP and I am pumping nearly 500 through mine. -It would also be nice to know that there was somewhere to go to FIND a replacement swing arm. With the professionalism of your fixtures, it looks as though you really know what you are doing! Any chance you would consider building a set of Swing Arms for me? Terry |
andys Custom Trailing Arms Jun 20 2005, 01:52 PM
andys Close up Jun 20 2005, 01:54 PM
andys Brake caliper weld fixture Jun 20 2005, 01:55 PM
andys Ooops, that's the trailing arm weld fixture.
... Jun 20 2005, 01:56 PM
andys Now, the brake caliper weld fixture with parts in ... Jun 20 2005, 01:56 PM
andys Another shot. Jun 20 2005, 01:57 PM
andys The bearing carrier, fits late 911 bearing Jun 20 2005, 01:59 PM
Mueller damn andy...that looks great <... Jun 20 2005, 02:11 PM
Travis Neff I dunno what is cooler, the fixture or the trailin... Jun 20 2005, 02:13 PM
ClayPerrine You should consider making the mounting tabs and f... Jun 20 2005, 02:25 PM
Jeroen that's friggin' awesome!!! Jun 20 2005, 02:26 PM
nocones So what are you saying here Andy, ...now that you... Jun 20 2005, 02:36 PM
airsix Jun 20 2005, 03:04 PM
andys Jun 20 2005, 03:11 PM
Jeroen maybe a little late, but how about one of those tr... Jun 20 2005, 03:13 PM
ClayPerrine Jun 20 2005, 03:15 PM
spare time toys You do know some one will see this and rip off you... Jun 20 2005, 03:41 PM
sixnotfour Didn't that Brad R. guy post a picture of a un... Jun 20 2005, 04:15 PM
Brett W Parts look great. Aren't CNC machines great. ... Jun 20 2005, 04:57 PM
andys *You do know some one will see this and rip off yo... Jun 20 2005, 05:16 PM
SpecialK I've seen a lot of assembly/mock-up jigs worki... Jun 20 2005, 05:22 PM
neo914-6 ... Jun 20 2005, 06:22 PM
andys Quick update......left side nearly complete.
And... Jul 13 2005, 10:30 AM
1bad914 http://www.914world.com/bbs2... Jul 13 2005, 10:44 AM
aircooledboy http://www.914world.com/bbs2/html/e... Jul 13 2005, 10:48 AM
jwalters DAMNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNN http://www.914world.com/bbs2... Jul 13 2005, 12:47 PM
michelko i am speechless http://www.9... Jul 13 2005, 01:49 PM
airsix How's the weight compared to stock? I wonder i... Jul 13 2005, 02:16 PM
andys Jul 13 2005, 03:34 PM
SpecialK You've got some mad design/fabrication skills ... Jul 13 2005, 04:35 PM
Terryst1 Hey 914ners:
Andy will probably get mad, but I... Jul 13 2005, 04:51 PM
SpecialK ... Jul 13 2005, 04:58 PM
tat2dphreak ... Jul 13 2005, 05:19 PM
Brad Roberts Cool.
Yes. I have/had jigs/fixtures for a 5 inch ... Jul 13 2005, 08:05 PM
Verruckt So when are these going to be available for sale, ... Jul 14 2005, 05:48 AM
redshift Unreal work, fantastic!
M Jul 14 2005, 06:08 AM
RON S. Jul 14 2005, 07:42 AM
andys Jul 14 2005, 12:03 PM
Mueller Jul 14 2005, 12:51 PM
andys The latest pic's to update my progress. The tr... Sep 12 2005, 12:31 PM
andys Don't ask me why I chose blue. It photographs ... Sep 12 2005, 12:34 PM
andys Wilwood mechanical spot caliper. I designed the pa... Sep 12 2005, 12:37 PM
Travis Neff That is trick! Sep 12 2005, 12:39 PM
tat2dphreak http://www.914world.com/bbs2/... Sep 12 2005, 12:41 PM
andys BTW, the heavy P-brake return spring is a must, ot... Sep 12 2005, 12:41 PM
Aaron Cox dude!!!
http://... Sep 12 2005, 01:29 PM
Andyrew when are they going in production!!! ... Sep 12 2005, 02:03 PM
914MF http://www.914world.com/bbs2/... Sep 12 2005, 02:35 PM
Britain Smith Those look awesome.
However, what is the advantag... Sep 12 2005, 03:52 PM
Aaron Cox Sep 20 2005, 11:32 AM
wbergtho I had Randy Beck in Upland, Ca fabricate my rear t... Oct 31 2005, 01:38 AM
redshift Ok Andy, you got the job. Starts tomorrow, $9... Oct 31 2005, 01:48 AM
Verruckt Andys
Eagerly awaiting the day when you start a n... Oct 31 2005, 05:42 AM
Brando Hot damn Andy, that's some marvelous work. Oct 31 2005, 01:11 PM
andys ... Oct 31 2005, 02:44 PM
Aaron Cox Oct 31 2005, 02:48 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 11:58 AM |
