Installing Autopower roll-bar. |
mihai914 |
Jun 20 2005, 08:39 PM
Senior Member Group: Members Posts: 800 Joined: 2-March 05 From: Montreal, QC Member No.: 3,697 Region Association: None |
I know it's pretty straight forward as to where to put the thing. What I want to ask about is the mounting.
I'll have the longs open, so should I weld some fabricated mounting plates in there when I have the chance. If I go this route, fine or coarse thread? I also heard about installing these with aluminium threaded rivets, but it sounds like it's going to rip out when you need it the most. I want to keep this thing a bolt-on application to use the thing only when needed for some DEs for example. Does it even make sence installing this thing while un-sagging the car? Thanks for the help. Attached image(s) |
URY914 |
Jun 21 2005, 07:18 AM
I built the lightest 914 in the history of mankind. Group: Members Posts: 121,070 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None |
My Autopower bar mounted to the floor not the top of the longs.
Weld in a "L" shaped base plate to the floor and up the side of the long. about 3". Install the bar, drill holes through and use another plate on the bottom and weld the nuts to the bottom plate. Stock autox classes say you can't weld in a roll bar. But you can weld in the mounting plate and bolt it the bar to it. Paul |
Lo-Fi Version | Time is now: 9th June 2024 - 03:42 PM |
