Blown Head Gasket, can it be changed in the car? |
fatlando |
Jun 27 2005, 10:08 AM
Member Group: Members Posts: 259 Joined: 6-September 04 From: imperial beach, california Member No.: 2,700 |
I haven't been able to take pictures yet, but everybody I've talked to said it sounds like a Head Gasket.
Is this painful $$$$ |
ClayPerrine |
Jun 27 2005, 01:03 PM
Life's been good to me so far..... Group: Admin Posts: 15,512 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
Actually, you CAN do it. But if you have a place to pull the motor, it's not worth it. At one point in time, I didn't have a place to put a 914 motor when it was out of the car. So I lowered the front of the motor enough to remove the head, and raised it back up until the head came back from the machine shop. I reversed the process to reinstall the head. Now I have a garage and that makes it all better....... If you have a place to remove and store the motor for the time it takes to do the head work, then I recommend just pulling the motor. It's easier to work on that way, and you are more likely to make a mistake working around the chassis stuff that would get in the way when doing it in the car. |
Lo-Fi Version | Time is now: 6th June 2024 - 05:13 PM |
