Pulled the heads-pics, Back-up race engine needs work |
groot |
Jun 29 2005, 07:37 AM
Dis member Group: Members Posts: 896 Joined: 17-December 03 From: Michigan Member No.: 1,444 |
As some of you know, #1 and #2 cylinders of my back-up race engine are pretty low on compression (110 and 115 psi) compared to #3 and #4 (145 and 150 psi). I squirted a bit of oil in the cylinders and the compression only gained a few psi.
So, I have a little break in the racing and I decided to pull the heads and do whatever valve work is required. Here are some pics. Looks like the intake valves hit the pistons a little bit, maybe on a over-rev during a downshift. Cyl #1 and #2 Attached image(s) |
groot |
Jun 29 2005, 10:40 AM
I just dropped the heads off with a local shop for a refresh. I'll take the cylinders in to him tomorrow to make sure we get a good fit and I'll run it without the top gaskets. The shop also suggested taking a little more out of the sealing groove to bump the compression a bit more, but we need to confirm that will work with these cylinders.
With these improvements, I'll have a bonified back-up engine for the monster Jake's building for me. Joe-the exhaust does look the same, but harder to see because of the carbon deposits. I don't have the history of who, what or when or how on this engine. I'm just happy that it has held together this long. I'll also order some rings once I confirm that I have 94mm cylinders. Thanks for the advice! |
Lo-Fi Version | Time is now: 2nd June 2024 - 01:19 PM |
