Rear shims, decreasing rear negative camber |
Gearren |
Jun 30 2005, 11:51 AM
Member Group: Members Posts: 91 Joined: 18-July 04 From: New Bern, NC Member No.: 2,362 |
Just got back from the alignment shop, got the front end dialed in near perfect! Cost only $38.00!! Rear camber is -1.50 left and right. In order to get it into "acceptable" limits, I need to lose 1 degree or 60 minutes of camber. The stock shim that is in the car is a 2mm. As I understand it, for each 1mm of shim I will get 10" of camber change. If that's correct, I will need to add 6mm of shim to each side! Problem is that I can only find shims as large 4mm. Is it acceptable to stack shims? Say 2 or even 3 shims on each side to total up to the required amount, or do you need to use a single shim?
xsboost90 |
Jun 30 2005, 02:15 PM
Senior Member Group: Members Posts: 1,393 Joined: 2-August 04 From: cincinnati Member No.: 2,432 |
mine had three on each side. Now it has 2 1/4 camber on the rear to clear properly.
Lo-Fi Version | Time is now: 2nd June 2024 - 01:52 PM |
