Valve adj/pushrod tube seals, Setting TDC before loosing rocker arms |
Mike Wofford |
Jul 20 2003, 10:46 AM
Member Group: Members Posts: 68 Joined: 29-April 03 From: Olympia, Wa. Member No.: 629 |
Question????? Do I set #1 to TDC before I loosen the Rocker arms. I am changing O-rings and need to do a valve adj. when done. Mike
tryan |
Jul 20 2003, 01:50 PM
Senior Member Group: Members Posts: 553 Joined: 22-January 03 From: smokey mountains gatlinburg tn Member No.: 184 |
you'll need to get tdc to set the vavles when you get done.
i would do a search on the torque specs for the rocker assemblies and what kind of sealant is recommended for the pushrod o-rings. you might want to download the pdf file. |
Lo-Fi Version | Time is now: 1st June 2024 - 12:06 AM |
