> idle issue, fluctuates at times
joeav8tor
post Jul 3 2005, 09:15 PM
Hello,
my 73 2.0 with stock fuel injection is running pretty good, but at times the idle fluctuates (not surging)...when the car warms up the car usually idles at 900 rpm...then at the next light or stop sign, it will idle at about 400 rpm...the idle is not consistant...further down the road it might idle at 900 rpm when I stop again...any ideas...I recently dropped the engine and installed new vacuum, fuel lines and did a complete tune up....the AAR is working properly...anyone else experience this problem?
thanks (IMG:http://www.914world.com/bbs2/html/emoticons/flag.gif)
Joe
ejm
post Jul 4 2005, 06:58 AM
I can see the light at the end of the tunnel
That engine pic looks like its from the factory brochure (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif)
The throttle body could be worn causing the closed position to vary. Check for wear at the throttle body shaft/bushing and inside between the plate and body.
joeav8tor   idle issue   Jul 3 2005, 09:15 PM
ejm   That engine pic looks like its from the factory br...   Jul 4 2005, 06:58 AM
bd1308   i always had funky idling problems with my FI....p...   Jul 4 2005, 07:33 AM
joeav8tor   thanks guys for the replies...Hi ED!   Jul 4 2005, 09:41 AM
!   LIGHTLY spraying carb cleaner at suspect areas and...   Jul 4 2005, 09:57 AM
BPGREER     Jul 4 2005, 03:06 PM
Bleyseng   yup. http://www.914world.com/bbs2/h...   Jul 4 2005, 06:23 PM
joeav8tor   yeah, I probably dont have it adjusted right...I w...   Jul 4 2005, 07:43 PM
MarkG   I am experencing same issue ('76 2.0, 20k on e...   Jul 5 2005, 10:45 AM
joeav8tor   my motor and car has 14,600 original miles, I drop...   Jul 5 2005, 11:13 AM
Engman   My vote is a vacum leak and / or TPS set wrong. Yo...   Jul 5 2005, 12:14 PM
- Lo-Fi Version Time is now: 2nd May 2026 - 06:16 AM
