> Starter issues
Bullet
post Jul 4 2005, 11:34 PM
I have had to replace 2 bosch starters in just a little over a year. Is it common for 914's to go threw starters often? I have ran redundent grounds and power to see if it was an issue with that and i still have the same problems. Would a heat shield help at all?
Bullet
post Jul 5 2005, 02:08 AM
on the 2 fail starters, it has been the solenoids that have gone bad. Turn the key and and the starter just clicks. If I use a starter switch the gear will spin but will not come out of the starter to engage the flywheel. Wacking the starter while the crank position is engaged will get it work, But I do not enjoy doing that. It is kinda embarasing.
Bullet   Starter issues   Jul 4 2005, 11:34 PM
Rand   No, starters don't fail that often, and a heat...   Jul 5 2005, 01:04 AM
Bullet   on the 2 fail starters, it has been the solenoids ...   Jul 5 2005, 02:08 AM
ablose58   Have you tried using a jumper directly from the ba...   Jul 5 2005, 02:18 AM
Bullet   <...   Jul 5 2005, 02:27 AM
ablose58   The seat interlock relay is under the pass seat an...   Jul 5 2005, 02:45 AM
Bullet   It is a 75 2.0L   Jul 5 2005, 02:49 AM
ablose58   You definitely have the relay! I have a 74 and...   Jul 5 2005, 02:52 AM
- Lo-Fi Version Time is now: 1st August 2025 - 04:40 AM
