> Starter issues
Bullet
post Jul 4 2005, 11:34 PM
I have had to replace 2 bosch starters in just a little over a year. Is it common for 914's to go threw starters often? I have ran redundent grounds and power to see if it was an issue with that and i still have the same problems. Would a heat shield help at all?
ablose58
post Jul 5 2005, 02:18 AM
rust never sleeps
Have you tried using a jumper directly from the battery to the trigger on the solenoid? Could be a few things in there that could contribute to this like seat interlock relay/ign switch or you could do as I did put on a gear reduction starter and no problems since (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif) AL
Bullet   Starter issues   Jul 4 2005, 11:34 PM
Rand   No, starters don't fail that often, and a heat...   Jul 5 2005, 01:04 AM
Bullet   on the 2 fail starters, it has been the solenoids ...   Jul 5 2005, 02:08 AM
ablose58   Have you tried using a jumper directly from the ba...   Jul 5 2005, 02:18 AM
Bullet   <...   Jul 5 2005, 02:27 AM
ablose58   The seat interlock relay is under the pass seat an...   Jul 5 2005, 02:45 AM
Bullet   It is a 75 2.0L   Jul 5 2005, 02:49 AM
ablose58   You definitely have the relay! I have a 74 and...   Jul 5 2005, 02:52 AM
- Lo-Fi Version Time is now: 1st August 2025 - 04:40 AM
