> Performance products Quick Shift, thoughts?
MattR
post Jul 4 2005, 09:36 PM
I know the rennshifter is the only way to go, but I cant spend 400+ on a shifter. I dont hate 901 shifting, but a shorter throw would be nice. Does the quick shift from performance products do that effectively? Or am I just asking for trouble?
rhodyguy
post Jul 5 2005, 08:01 AM
i believe the one howard has pictured is for a tailshifter. note the ball on the bottom that goes into the ballcup bushing on the front shift rod. for a sideshift trans, the front rod connector found on the stock shifter is used. i noted the effort to shift increased when i went to the wietmiester, which fyi, requires no cut-epoxy-etc. as stated, if the bushings are bad, a shortshift conversion is no cure. check the springs on the R/1 indent plate (you have to remove the shifter), usually they are loaded with grease, dust/dirt, and gunk. spray them down with carb cleaner or berryman's to clean them.
k
- Lo-Fi Version Time is now: 8th December 2025 - 02:42 AM
