| brer |
Jul 5 2005, 08:05 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,555 Joined: 10-March 05 From: san diego Member No.: 3,736 Region Association: None |
Put the rocker assemblies back on my heads and drove home to san diego.
got very loud rocker noises coming from the engine re adjust the valves. drive it for a little while and bigger clacking noise and starting to lose power. (IMG:http://www.914world.com/bbs2/html/emoticons/sad.gif) I think i *effed* it up installing the new studs and then torqing the rocker assembly nuts with my old torque wrench. thought i seated the studs properly, and torqued the nuts right, but now the valves dont seem to be holding an adjust. so what the worst that could have happened? stripped the studs from the heads right? |
| Type 4 Unleashed |
Jul 5 2005, 10:21 PM
CREATIVE TYPE lV ENGINEERING ![]() ![]() ![]() Group: Retired Members Posts: 787 Joined: 20-June 04 From: Aliso Viejo, ca Member No.: 2,231 Region Association: None |
[QUOTE]Every time i adjusted them they would be quiet for a few days then get noisy again. So, there was something, going on before, you tried to put the new rockers on. Before, did you notice, when you were adjusting the rockers, if it was always the same ones that were loose? Always look for something out of the norm. After you spend some much time working on your motor, you will know every little noise it makes and why, and this goes for everyone, I have no better way to say it, other than you then become one with your motor. (IMG:http://www.914world.com/bbs2/html/emoticons/happy11.gif) |
brer I think maybe I... overtightened Jul 5 2005, 08:05 PM
McMark Time to pull of the rocker assemblies and really g... Jul 5 2005, 08:42 PM
brer any way to tell if the stud is starting to pull ou... Jul 5 2005, 08:44 PM
Dr Evil Yes, look at how much is sticking out past the nut... Jul 5 2005, 08:59 PM
brer they were the original holes.
I'm thinking th... Jul 5 2005, 09:12 PM
V6914 Jul 5 2005, 09:55 PM
bd1308 you mean like grinding down a cam....how often doe... Jul 5 2005, 10:13 PM
V6914 Jul 5 2005, 11:02 PM
brer I've only adjusted the valves once since i got... Jul 5 2005, 11:44 PM
V6914 Jul 6 2005, 12:42 AM
ArtechnikA Jul 6 2005, 05:34 AM
bd1308 Jul 6 2005, 06:24 AM
DonTraver Hey Bear, once you get the engine out, you could b... Jul 6 2005, 07:56 AM
brer went out and turned her over to listen again.
the... Jul 6 2005, 07:50 PM
Elliot Cannon Jul 7 2005, 10:20 PM
brer it aint fixed yet! http://w... Jul 7 2005, 11:09 PM
Jake Raby I have the new German wavy washers in stock..... I... Jul 7 2005, 11:16 PM
brer ok, i'm not giving up yet.
ht... Jul 7 2005, 11:30 PM
Jake Raby NEVER give up...
If you want something with a Sub... Jul 7 2005, 11:37 PM
brer i still have this to play with.
I'm talking a... Jul 7 2005, 11:45 PM
Jake Raby 60 was a good year...
Its needs a MassIVe 4...
O... Jul 8 2005, 12:00 AM
brer I was thinking of rebuilding the original 36hp.
W... Jul 8 2005, 09:21 AM
brer so i put the new rocker assembly's on with .03... Jul 15 2005, 03:41 PM
brer BTW- it lives! going for a little drive. ... Jul 15 2005, 08:08 PM
bd1308 I love beetles.....it would be so cool to have one... Jul 15 2005, 08:14 PM
brer all i have to say now is.
h... Jul 15 2005, 10:03 PM![]() ![]() |
Lo-Fi Version | Time is now: 12th July 2026 - 03:49 AM |
