> Tires 195/55/15 or 205/50/15
grantsfo
post Jul 22 2003, 11:47 PM
Arrrrhhhh!
I'm shopping for tires now. I have found a few interesting tires in 195/55/15, but was wondering about 205/50/15. I know clearence for 205/50's depend on tire and car, but regardless of clearence what would work better on a stock powered 1.8 with koni's, sway bar slightly lowered etc. I know that fatter tires dont always equate to better performance. Should I consider 195/50/15's to minimize rotational weight on my stock powered car?
Looking for dry weather tire I can use on street and for AX.
Anton
post Jul 23 2003, 03:53 PM
Royal Orange
QUOTE(ninefourteener @ Jul 23 2003, 11:17 AM)
I run a set of 205/60's on all 4 corners with 4-lug fuchs.  My suspension is all brand new, and 100% stock, and there is no rubbing anywhere, even at full turns.
Remarkable. I use the standard 5.5 J x 15 steel rims with an off-set of 40mm (ET40 = "einpress tiefe") and the right tyre touches the inside fender on full turn.
Do Fuchs rims have a different width (I thought they were 5.5 J as well) or off-set?
Heard good things about Kuhmo's, haven't driven them yet. I regularly do 110 MPH (for short distances) on the high way, so that's another reason why I am so anxious about tyre quality.
grantsfo   Tires 195/55/15 or 205/50/15   Jul 22 2003, 11:47 PM
SirAndy   go with the 205/50 if they fit ... you'll be h...   Jul 22 2003, 11:49 PM
Scott Carlberg   <...   Jul 23 2003, 01:55 AM
Anton   WRONG SIZE! Tyre outside diameter should be t...   Jul 23 2003, 06:00 AM
vsg914   Original tires suck! Anyone who's ever dri...   Jul 23 2003, 06:44 AM
tod914   I put the 195 60 15 on mine - spedo is off by mayb...   Jul 23 2003, 07:19 AM
seanery   I think 195's are the way to go. I've run...   Jul 23 2003, 08:24 AM
Anton   About tyre brand: A 914 has exemplary steering be...   Jul 23 2003, 12:50 PM
ninefourteener   I run a set of 205/60's on all 4 corners with ...   Jul 23 2003, 01:17 PM
redshift   Let's play ball! 205/65 :) You guys ne...   Jul 23 2003, 01:24 PM
grantsfo   I have driven a several 914's through the year...   Jul 23 2003, 01:47 PM
Scott Carlberg   ...   Jul 23 2003, 02:02 PM
Bleyseng   I have run the 195x60's and the 205x50's o...   Jul 23 2003, 02:07 PM
grantsfo   Tire rack has KUHMO ECSTA MX in 205/50/15 for ...   Jul 23 2003, 02:29 PM
Ferg   I've pretty much decided to go with the falken...   Jul 23 2003, 02:41 PM
tat2dphreak   DUDE VSG, I have those same Rims! :boing:   Jul 23 2003, 02:43 PM
vsg914   Ferg, right you are! tat2dphreak, I think the...   Jul 23 2003, 03:09 PM
redshift   Yeah VSG, those are Westerns, my favorite. With y...   Jul 23 2003, 03:24 PM
vsg914   70mph-4th gear-4000rpm 5th gear-3200rp...   Jul 23 2003, 03:50 PM
Anton     Aug 28 2003, 12:06 PM
-P-   Man, I can barely fit my pinky between the fender ...   Aug 28 2003, 12:21 PM
Dave_Darling     Aug 28 2003, 01:01 PM
Racer   Ask enough people and you'll get too many answ...   Aug 28 2003, 04:47 PM
- Lo-Fi Version Time is now: 12th March 2026 - 12:09 AM
