> oil cooler temp
post Feb 6 2003, 06:05 PM
Resident German
anyone ever bothered to measure the running temp of a front-oilcooler?
does it even get hot enough to use it as a heater "replacement"?
brad said that he doesn't like the front-coolers that route the air upwards
with an exit through the trunk lid because you get all the hot air in the car
when the top is off.
question is, does it really get that hot?
if yes, i could route the air from the front cooler under the hood right into
the inside to get some heat.
what'ya'think?
J P Stein
post Feb 7 2003, 03:39 PM
Irrelevant old fart
Brant:
It sounds as though you've done your homework and done your compromises......reality vs ideal....as we all must. Mounting the cooler in the front trunk is a compromise.....air flow vs back pressure....take your pick,eh?
A Troutman or Porsche thermostat is about as good insurance against back pressure as there is....due to it's pressure reilef valving. I found the troutman awkward to mount and plumb....see pic...in the space I had available. Thus some 90s both there and at the cooler.
Vintage racin' groups seem not to be able to get together
on rules structure. Up here guys can run 2.5L 914s....and that ain't enuff against the 240Zs....or so I was told by a 914 vintage guy.
SirAndy   oil cooler temp   Feb 6 2003, 06:05 PM
seanery   Andy, What about those days when it's 90+ deg...   Feb 6 2003, 06:08 PM
SirAndy     Feb 6 2003, 06:14 PM
seanery   Here's a question that may help you find an an...   Feb 6 2003, 06:20 PM
brant   andy, again, take this with a grain of salt. It...   Feb 6 2003, 06:29 PM
Jeroen   Be carefull! If a your cooler gets hit and spr...   Feb 6 2003, 06:43 PM
SirAndy   good points guys, the air flow needs to be as smoo...   Feb 6 2003, 07:18 PM
J P Stein   The cooler gets plenty hot. The thermostat on my c...   Feb 7 2003, 01:30 AM
Brad Roberts   Andy, JP's cooler is the same one/size I run ...   Feb 7 2003, 02:19 AM
Dave Cawdrey   Here's my cheapie oil cooler. It says (shown ...   Feb 7 2003, 02:57 AM
Dave Cawdrey   here's what I mean...   Feb 7 2003, 02:58 AM
seanery   JP, are those 3 holes the only venting for that ...   Feb 7 2003, 08:43 AM
brant   JP, Brad.... which fluidyne is that. It looks li...   Feb 7 2003, 09:09 AM
J P Stein   Brant: The cooler is a 34016. 2 34017s? Whatdaya g...   Feb 7 2003, 12:42 PM
Dave_Darling   Dave (korijo), a few problems with your setup... ...   Feb 7 2003, 01:05 PM
brant   JP, I'm sick of too high of oil temp. In th...   Feb 7 2003, 01:14 PM
J P Stein   OK, we're in agreement on heat. I feel free ...   Feb 7 2003, 02:10 PM
brant   cool lots of interesting tidbits... where to star...   Feb 7 2003, 02:39 PM
J P Stein   Brant: It sounds as though you've done your h...   Feb 7 2003, 03:39 PM
brant   JP, thanks for your thoughts... and thanks for t...   Feb 7 2003, 07:11 PM
- Lo-Fi Version Time is now: 16th July 2025 - 05:08 PM
