> Identifying and Dealing with EMI, searching and searching
McMark
post Jul 25 2005, 09:12 PM
914 Freak!
I would like to spend some serious time doing a qualitative analysis of the EMI that is probably going on in my engine bay. I've been searching Google for some write ups that might help me get started, but everything seems to be quick marketing blurbs for every electronics company on the planet. Does anyone have some links or books or anything that might help me?
Here is how I would like to approach the problem:
1. Evaluate my current situation.
2. Identify the sources.
3. Implement effective corrective measures.
4. Judge the effectiveness of my efforts.
This is probably over the top, but being the son of an engineer makes me think this way. (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif)
So give me your best links and books regarding identifying and dealing with EMI, please.
lapuwali
post Jul 25 2005, 10:26 PM
Not another one!
Don't try to reduce the EMI, shield against it. The ignition is going to generate a lot of EMI, no matter what you try.
I'm assuming this is your one-off Kit Carlson setup? If so, make sure the electronics are sealed in a metal box, and that the box is grounded. Twist any sensor wires that come in pairs together, as this reduces their sensitivity to noise. If this isn't enough, or you have a single sensor wire picking up noise, cover it with conducting braid with one end grounded.
Run separate ground wires for sensors showing too much noise (TPS tends to be susceptible to this), rather than running the signal ground through the car body. Again, do the twisted pair thing with these.
McMark   Identifying and Dealing with EMI   Jul 25 2005, 09:12 PM
GWN7   Yep, over the top, no need to put the EMI in there...   Jul 25 2005, 10:21 PM
lapuwali   Don't try to reduce the EMI, shield against it...   Jul 25 2005, 10:26 PM
bd1308   somebody i thought said that having multiple groun...   Jul 25 2005, 10:35 PM
McMark   I'm wondering if I can use my oscilloscope for...   Jul 25 2005, 11:16 PM
TonyAKAVW   Never underestimate the need for a good source of ...   Jul 26 2005, 03:02 AM
DNHunt   Mark Don't forget proximity. Move things away...   Jul 26 2005, 07:44 AM
KitCarlson   Mark, All, I am back and hope I can be of help. ...   Aug 19 2005, 07:56 PM
john rogers   I had some EMF or whatever you want to call it whe...   Aug 19 2005, 08:09 PM
Britain Smith
- Lo-Fi Version Time is now: 1st July 2025 - 07:42 AM
