Electrical problems, Weird stuff happening |
#1RAGE |
Jul 25 2005, 04:44 AM
Member Group: Members Posts: 139 Joined: 7-May 03 From: Saskatoon, SK, Canada Member No.: 664 |
During my long road trip (~2300 miles) I had some weird electrical problems pop up.
The first thing I noticed was that the spedometer needle was bouncing up and down a few mph at a constant pulse. At first I thought it was dying on me but now I think it has to do with other things. Then much later on I relalized my signal lights on the passenger side weren't working at all. Checked bulbs, fuses and tried again and then I noticed other problems. My brake light started working after never working before... except it would start flashing along with the signal light indicator. One brake light was really bright. Sometimes one rear light wouldn't work. Sometimes my reverse lights would be stuck on when the headlight knob was either 1/2 way out or full out. The hazard lights would work randomly. The gas and speedometer gauges would bounce. There are probably other things that I forgot about. Anyway, all those weird things started happening then everything started working again a few hours later. Then the next day it went back to not working properly. I'm guessing it is a grounding issue but I have no idea what to look for. It rained a lot while traveling. I'm wondering if maybe something got wet and screwed things up? Any suggestions? Thanks |
bperry |
Jul 26 2005, 11:09 PM
Lurker Group: Members Posts: 477 Joined: 16-February 04 From: Dallas, Tx Member No.: 1,661 |
I've seen the speedo needle bounce due to the inner cable binding
because the cable dropped down and landed on the heat exchanger or header. Its fairly obvious, looks for the melted spot on the cable. --- bill |
Lo-Fi Version | Time is now: 7th June 2024 - 12:47 AM |
