fuel pump surging, why?? |
Tab914 |
Aug 1 2005, 06:52 PM
Member Group: Members Posts: 158 Joined: 25-April 04 From: Alexandria, Ontario, Canada Member No.: 1,978 Region Association: Canada |
Another one for you guys...........
Here is the problem I am trying to fix. Whenever the needle in the temp guage gets to about 1/4 the fuel pump starts surging. This causes the idle to start to go up and down in rythm with the fuel pump. Also when under load the car stutters and shudders and kinda wants to choke. Before the car gets up to that temp. it runs nice and smooth, strong on acceleration and no poping or backfiring on decel or anything. Just sounds great and runs fine. Idle is where it should be and fuel pump does not surge. Here is what has been done. -Valve adjustement -Dwell adjustement -Timing adjustement -Tested MPC as per proper ohms. Parts I have changed- coil, plugs, ignition points, trigger points, condenser, rotor, cap and wires. Questions:- what could make the pump surge like that? -does it make a difference how the MPC wire goes into it's conector? -How do I properly check the head temp sensor. -Could the intake temp. sensor be the cause. I am at a lost. Feel like I am going in circles. (IMG:http://www.914world.com/bbs2/html/emoticons/confused24.gif) Has anyone had this kind of problem?? Desperate for advice. (IMG:http://www.914world.com/bbs2/html/emoticons/sad.gif) Thanks, Dominic. forgot to add. car is a 1974 2.0 with stock fuel injection. |
Tab914 |
Aug 1 2005, 10:46 PM
Well from the paper work the fuel pump is the right one. The PO had gotten it from a PORSCHE dealership. # 311-906-091 $550.00 Canadian. Good news is I had bought the car for $800.00. Anyway when I picked up the car the PO could not get it running. After fiddling with the fuel pump (disconecting and reconecting a dozen times) I got it to run. Is it possible the hoses are in the wrong ports but the car still runs? (IMG:http://www.914world.com/bbs2/html/emoticons/wacko.gif) Seems unlikely to me but you probably know better.
As for the vapor lock from the fuel lines in the engine bay as I asked about earlier, am I having symptoms that resemble vapor lock?? (not sure what vapor lock does). |
Lo-Fi Version | Time is now: 6th June 2024 - 11:23 AM |
