fuel pump surging, why?? |
Tab914 |
Aug 1 2005, 06:52 PM
Member Group: Members Posts: 158 Joined: 25-April 04 From: Alexandria, Ontario, Canada Member No.: 1,978 Region Association: Canada |
Another one for you guys...........
Here is the problem I am trying to fix. Whenever the needle in the temp guage gets to about 1/4 the fuel pump starts surging. This causes the idle to start to go up and down in rythm with the fuel pump. Also when under load the car stutters and shudders and kinda wants to choke. Before the car gets up to that temp. it runs nice and smooth, strong on acceleration and no poping or backfiring on decel or anything. Just sounds great and runs fine. Idle is where it should be and fuel pump does not surge. Here is what has been done. -Valve adjustement -Dwell adjustement -Timing adjustement -Tested MPC as per proper ohms. Parts I have changed- coil, plugs, ignition points, trigger points, condenser, rotor, cap and wires. Questions:- what could make the pump surge like that? -does it make a difference how the MPC wire goes into it's conector? -How do I properly check the head temp sensor. -Could the intake temp. sensor be the cause. I am at a lost. Feel like I am going in circles. (IMG:http://www.914world.com/bbs2/html/emoticons/confused24.gif) Has anyone had this kind of problem?? Desperate for advice. (IMG:http://www.914world.com/bbs2/html/emoticons/sad.gif) Thanks, Dominic. forgot to add. car is a 1974 2.0 with stock fuel injection. |
Tab914 |
Aug 2 2005, 01:29 PM
Hey Mihai!
I don't think that the last owner was the one to relocate the fuel pump. He didn't seem to have much of a clue. So I don't know. I am trying to get a fuel pressure tester and hopefully get that done today. Another thing that just dawned on me and I guess it should have sooner is that the Heat temp. sensor is located neer the #1 cylinder (in a makeshift hole in the engine tin) where it says everywhere (the books) that it should be near the #3 cylinder. Would that make a difference in any of the readings?? Is there a port in the head on that side of the engine for a temp. sensor or was some weird stuff done here?? I am baffled. (IMG:http://www.914world.com/bbs2/html/emoticons/confused24.gif) Is it possible that the engine was rebuilt and that the heads were switched around by mistake. Would they fit and still work???? |
Lo-Fi Version | Time is now: 8th June 2024 - 01:23 AM |
