bd1308 |
Sir Post-a-lot ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,020 Joined: 24-January 05 From: Louisville,KY Member No.: 3,501 ![]() |
you said in a previous post that one should not go below 3500RPM in 5th gear, as the airflow is not sufficient enough for proper cooling.
i have some problems with this.... 1) in my car, at 70mph, I am around 3200RPM in 5th...sometimes i am even running 3000RPM and occasionally run even 2800RPM for short periods of time. Are you suggesting that I should not shift into 5th gear at all? 2)I have also heard that the type 4 cooling fan efficiency goes down after around 4000RPM....it was mentioned by someone on this board, but the user name escapes me. Is this true? I tried running 75 in 4th gear and I was running more than 4000RPM..... I think i am missing something.... |
bd1308 |
i keep up with traffic, and i'm doing 4000rpm in 4th gear. explain that?
did i get the ultra rare ring gear upgrade or what? |
Lo-Fi Version | Time is now: 1st August 2025 - 11:03 AM |
