| ewdysar |
Aug 3 2005, 03:42 PM
What happens here, stays here. ![]() ![]() ![]() Group: Members Posts: 558 Joined: 29-October 04 From: Altadena, CA Member No.: 3,030 |
So, I've noticed alot of movement in the plate that the accel cable and pedal rod attach to. I figured that it was bushings, but when I pulled the floorboard and cables, I noticed that the shaft for the plate seems OK, the plate is loose on the shaft. That's not right, is it? I haven't pulled the whole cluster yet. How does the plate attach to the shaft? Can it be tightened? The thottle cable gets hung up (stuck thottle (IMG:http://www.914world.com/bbs2/html/emoticons/ohmy.gif) ) under the floor board if I don't have alot of slack in it.
TIA, Eric |
Porsche Rescue Happen to have mine on the bench. Shaft goes throu... Aug 3 2005, 04:00 PM
Cap'n Krusty Actually, it's furnace brazed. Need to clean ... Aug 3 2005, 04:10 PM
ewdysar Pulled the cluster, removed the accel pieces. Wen... Aug 3 2005, 11:58 PM![]() ![]() |
Lo-Fi Version | Time is now: 10th March 2026 - 09:31 PM |
