Tail shifter shaft, It's all worn out! |
Jaiden |
Aug 4 2005, 07:36 AM
Member Group: Members Posts: 346 Joined: 13-January 05 From: Stroudsburg PA Member No.: 3,443 |
So I had the car up on Jack stands last night to take a closer look at some of the things I have on my To Do list and While inspecting the shift linkage I notice that instead of finding that my sloppy shifting is due to worn bushings I found that the actual shaft is worn out!!!
Also where the shaft sets into the tranny shift linkage should there be a bushing there or just grease? Now how can I go about fixing this? I took a look at how the shaft is mounted and up front the bushing is good but I'm not sure how to remove the shaft. I would like to either replace the shaft or possibly increase the diameter with added metal or even epoxy. I don't mind the tailshifter as I feel a properly set up peice should work fine. Any Ideas? |
Joe Ricard |
Aug 4 2005, 07:42 AM
CUMONIWANNARACEU Group: Members Posts: 6,811 Joined: 5-January 03 From: Gautier, MS Member No.: 92 |
I've got a whole tail shift set up. Let me know I'll make you a sweet deal. It looks to be in good shape.
Lo-Fi Version | Time is now: 6th June 2024 - 01:46 PM |
